Branding en lay-out instellen
Hello comm!
I’m kind of new doing community work and worked on layout, I have experience in HTML/CSS and customized a new navigation bar to add a few links but I would like to removed the default logo branding :
Is there any “easy” way to that (we are hosted, just in case).
Many thanks,
PT
hi @PT_LB you can try this in common css of a theme or theme component:
.d-header .title {
    display: none;
Works like a treat, thank you @Lilly !
no problem, glad that helped :slight_smile:
