Broken layout for admin login
After updating to Discourse 3.4.0.beta2-dev, an admin user experienced a broken layout upon login, while the master admin’s layout remained unaffected. GeniusConsulting sought help, prompting suggestions to test safe mode ondrej and check browser console errors Moin. Trumpolin confirmed safe mode didn’t resolve the issue. Lhc_fl identified Cloudflare’s ‘Auto Minify’ as the culprit, referencing Discourse’s official guidance to disable it (alongside Rocket Loader™) for compatibility. After disabling Auto Minify and purging Cloudflare’s cache, GeniusConsulting confirmed the layout was restored to normal. The root cause was Cloudflare’s minification interfering with Discourse’s JavaScript, even when Rocket Loader™ was off.
After last update to 3.4.0.beta2-dev version, when one of our Admin users login he got a broken layout as on screenshot.
Master admin user layout looks just fine.
Any idea ?
Have you tried safe mode to rule out and theme / plugin / theme component issues?
Any errors in the browser console?
Edit: Apparently yes
@ondrej the safe-mode doesn’t help and leads to the same issue.
Hi
Are you using Cloudflare? Cloudflare’s auto-minify will cause this.
Thank you guys, it is solved now…
Indeed was issue with Cloudflare, even Rocket Loader was off, Auto Minify was on, and after disabling and purge cache, layout back to normal!
