Someone knows if is possible to integrate with liquid template system? Liquid template language. Thanks in advance.
Why would you need liquid templates for?
Hi @zogstrip, because we are using teachable.com as Learning Managment System platform and we want to integrate Discourse to each lecture. How we can integrate it? We don´t want the user leaves the lecture so a thread embedded would be a great solution.
If you want then to be able to read some comments about a lecture in the same page, you can use Javascript for that.
If you want then to comment, that’s not supported.
