Is it possible to (via a plug-in if necessary) randomly choose a logo (and small logo) from a set of 3 every time someone starts a new session (or until their browser refreshes the assets for the logo)?
The Ruby code is trivial - but how can we incorporate that into Discourse?
This is doable in a theme component, the method by @Alankrit_Choudh can work but I would recommend adding a custom ember initializer instead that overrides the URL in discourse instead of relying on window.onload here.
I’ve run up against the same problem. window.onload works if called before </head>, but not if called later. And because of that, document.getElementById fails (the ID isn’t defined yet).
Could you point me to a primer/example/howto for how to create a custom ember initializer for someone who has no experience with ember?
For completeness, what I’m trying to do is display a random banner image from an array of URLs:
var jlmyPix = new Array(
'/img/pic0.jpeg',
'/img/picN.jpeg'
function jlchoosePic() {
var jlrandomPicNum = Math.floor(Math.random() * jlmyPix.length);
document.getElementById("jlmyPicture").src = jlmyPix[jlrandomPicNum];
window.onload = jlchoosePic;
