Cannot login to meta using Discourse App
I am unable to login to this instance with this discourse app on an iPhone running the latest iOS.
I delete this instance from the app, restart the app, re-add meta.discourse.org.
I eventually get an “oops” page from the server.
I have no other process flow I can try. If I cancel the initial dialog I cannot connect. And I don’t even get to enter my username.
Sorry about that @orenwolf. Can you try again now?
The underlying issue is a bug in the mobile app where sometimes deleting the app or removing a site from the app doesn’t delete the accompanying DB record on the server. I went ahead and deleted that record on your account, so adding meta.discourse.org to the app should work with no errors for you.
That did it. Thanks!
