I did follow the docs and, however, it only update the topic’s title, without updating the body.
My code (Javascript):
async function updateDiscourseTopic(topic_id) {
const Discourse_API_Key = "Discourse_API_Key";
const url = `https://discourse.mysite.com/t/-/${topic_id}.json`;
const payload = {
title: 'session_1',
raw: "new body(doesn't apply)"
const response = await fetch(url, {
method: 'PUT',
headers: {
"Api-Key": Discourse_API_Key,
"Api-Username": "system",
"Content-Type": "application/json",
body: JSON.stringify(payload)
Lilly
(Lillian )
May 11, 2023, 1:01pm
just a guess from looking at the code, but perhaps it may be because you are using topic_id instead of post_id? because first post is the topic in Discourse, more or less?
Canapin
(Coin-coin le Canapin)
May 11, 2023, 3:31pm
3
@Lilly ’s right.
A topic is defined by attributes like title, category, tags, etc.
But the content belongs to a post .
If you want to update the title and the content, you need 2 requests.
PUT on the topic
PUT on the first post. You can find the post’s ID in the HTML code of the page. Look for the data-post-id attribute in <article>.
Example:
<article id="post_2" aria-label="post #2 by @Lillinator" role="region" data-post-id="1288311" data-
topic-id="264640" data-user-id="127856" class="boxed onscreen-post">
Wow, you are right, it works
And I figured out how to retrieve the ID of the first post in a topic using the Discourse API:
async function getFirstPostIdFromOnetopic(topic_id) {
const url = `https://discourse.mysite.com/t/${topic_id}/posts.json`;
method: 'GET',
headers: {
const data = await response.json();
const firstPostId = data.post_stream.posts[0].id;
return firstPostId;
Thank you and @Lilly
