Category Highlighter
This theme component lets you highlight a category (or categories) in your Discourse. You can:
  1. Give specific categories a special background style
  2. Add a category link to the header with the same special style
An example use case is for a category with “Premium” content.
:wrench: How to install
:computer: Get the code
Category Navigation and Header Label
Categories page
Configuration
The category highlighter theme component has one main setting “highlight categories”. You’ll find this setting in the Category Highlighter theme component setting panel.
Each category you want to highlight has its own list item in this setting. The format of each item is:
category_slug~background~text_color~header_label~header_label_mobile~parent_slug~alternate_link
An example of this format is:
premium~linear-gradient(319deg, #cdedfd 0%, #ffec82 37%, #ffcfd2 100%)~#88562e~:star:&nbsp&nbspPremium~:star:
There are six possible values, each separated by ~ (a “tilde”). Let’s go through each value in turn.
Category Slug
This is the “slug” of the category you want to highlight. You can find it in your category settings.
If you need to highlight a sub-category, you need to use the “Parent” category slug, then the sub-category slug separated by a /.
For example, if there was a sub-category of premium with the slug videos that I wanted to highlight, I would use:
premium/videos
Permissions
Note that only those users who have read permissions for the highlighted category will see the highlights, including the header label. You can change your category permissions in the category “Security” settings.
Background
This is a value that will be given to the background css property of the category badge. You can use any entry here that that property supports.
background - CSS: Cascading Style Sheets | MDN
The background shorthand CSS property sets all background style properties at once, such as color, image, origin and size, or repeat method.
For example linear-gradient(319deg, #cdedfd 0%, #ffec82 37%, #ffcfd2 100%).
Text Color
This is a value that will be given to the color css property of the category badge. This affects the color of the text. You can use any entry here that that property supports
color - CSS: Cascading Style Sheets | MDN
The color CSS property sets the foreground color value of an element’s text and text decorations, and sets the currentcolor value. currentcolor may be used as an indirect value on other properties and is the default for other color properties, such…
In our example case this is #88562e.
Header Label
This value serves two purposes. It determines:
  1. whether the highlighted category will get a header label; and
  2. the contents of that label.
If you don’t want a header label, don’t include this value at all.
This value supports text, html entities and emoji.
The header label value here is: :star:&nbsp&nbspPremium. Thats:
  1. The shortcode for the star emoji: :star:
  2. Two non breaking space html entities (these each add a white space): &nbsp&nbsp
  3. Our label text: Premium
You can find full list of emoji shortcodes here, and a full list of html entities here.
Mobile Header Label
This value also serves two purposes. It determines:
  1. whether the highlighted category will get a mobile header label; and
  2. the contents of the mobile header label.
The usage and formatting is the same as the Header label. One thing to note here is that you have less space on mobile, so it might be prudent to just use an emoji, or a short word to save space.
Parent Category
You can create a dropdown in the header by setting the “parent” of an item. Insert a category slug as the sixth item and the relevant item will become a sub-menu item of that category in the header. As with the first item, make sure you use the category slug here, which you can retrieve from the category settings modal.
Alternate Link
By default each category item links to the category it relates to. You can change the link by adding a url as the sixth item in the setting block.
25 个赞
So simple, yet so impactful. I have had the plan for a while to CSS certain parts of the forum to highlight posts from the paid customer categories. That makes everything much easier now. Thx for the work, this is amazing!
Have you thought about highlighting topics in the topic list when all categories are active in the category picker? For example add the star before the topic title?
2 个赞
The highlight works in all places the badge appears, so it’s there in the list already :slight_smile:
Topic List Site Menu
site_menu
Categories page
See further https://try.thepavilion.io
4 个赞
@Angus, you’re an amazing developer and it is a tremendous pleasure to collaborate with you. Thank you for your creativity, excellence, and thoroughness. You are a gift to the Discourse community.
6 个赞
This is a pretty cool component, nice work :+1:
7 个赞
ooo that feels so… :sparkles: preeemium
10 个赞
I thought there is a sidebar at first glance. A sidebar with this style could be nice.
Great component, really nice. :+1:
@angus I would like to know how to put a border-radius on the highlighted background, thanks in advance.
1 个赞
Due to the variety of contexts the category badge appears in this is a little complex. I might add a class to make this a bit easier, but for now you can do this:
### Header button
.highlight-category-button {
    border-radius: 4px;
### Badges
.badge-wrapper[class*=" updates "],
.extra-info-wrapper .categories-wrapper .badge-wrapper[class*=" updates "],
.category-title-link-component[class*=" updates "] .category-text-title,
.select-kit.combo-box.category-drop .category-row[class*=" updates "] .badge-wrapper {
    &:before {
        border-radius: 4px;
“updates” is the category slug in the example
Example: https://try.thepavilion.io/
2 个赞
The component now supports a category dropdown. :tada:
If you use the parent category slug as the 6th item in the settings, it’ll will show a dropdown with the child categories as the dropdown items.
Note: You will have to pass the 5th item i.e. (Header label mobile ) as empty if you don’t want to use it.
Thanks for sponsoring this @outofthebox .
4 个赞
Great work @fzngagan!! The Pavilion team is stellar.
2 个赞
Could be possible to highlight not only the slug, but .select-kit .select-kit-row.is-highlighted?
Screenshot_20210911_125206
It could be better for our eyes, I think.
I agree with comments: your work is awesome. I was looking into Pavilion site and I’m testing a lot of stuff.
I’ll hope that we work soon on some ideas that we have for our community :ok_hand:
First of all thanks for this awesome component.
I think this would look better if these was a little more whitespace between topic title and category badge in topic list view. Can this be achieved within the component? It seems the boxed are a little bit bigger than default boxed view, it creates a painful view to some perfectionists, lol.
Mobile view is better then desktop view:
这个还能用于最新的测试吗?如果可以,你那里还有存档的文档吗?@angus
我已将文档粘贴到上面的 OP 中。如果不起作用,请告诉我。
1 个赞
太棒了!尤其是渐变部分对于实现我的目标至关重要!非常感谢!
1 个赞
是否还有人在使用这个 TC,并且可能找到了以下问题的解决方案?
在 2.9.0.beta9 和 beta10 上,TC 导致系统类别元数据从类别下拉字段和主题列表中消失。
论坛日志为空,控制台日志中唯一的内容是:
[THEME 190 'Category Highlighter'] 为了防止测试出错,请在 `modifyClass` 调用中添加 `pluginId` 键。这将确保修改只应用一次。 3 plugin-api.js:19
