The Codebytes plugin allows users to embed executable, editable code blocks directly in forum posts and replies. It supports multiple programming languages, including Python 3, Ruby, JavaScript, C++, C#, Go, and PHP.
Key Features
Embed and execute code directly in forum posts and replies
No setup required; write, share, and run code directly in the browser
Read, write, and edit code in multiple programming languages
Interact with Codebytes directly in posts without copying and pasting into an IDE
Limitations
Not optimized for mobile experiences
Examples and Screenshots
The plugin’s usage is demonstrated in Example 1, Example 2, and Example 3. Screenshots show how to create a Codebyte, select a language, and edit the code.
Troubleshooting
Chan_Patrick reported an error and provided a fix, suggesting to add a pluginId key to the modifyClass call. alekz requested more details to reproduce the issue.
PLUGIN discourse-codebytes-plugin] To prevent errors in tests, add a `pluginId` key to your `modifyClass` call. This will ensure the modification is only applied once.
