Columns in raw compare view
The view of the new post is not under the new title. It is under the old title but a little indented.
Oh, nice catch. This is because of recent commits I made.
https://github.com/discourse/discourse/pull/21474
These commits improved the table layout in the history view, which happens to be entirely contained in a table element hence the issue.
I didn’t check if it affected the raw view. I’ll fix this next week unless someone wants to do it before. :slight_smile:
It should be fairly easy to fix, as the HTML view has a .revision-content class container, whereas the raw view doesn’t.
It’s fixed :slight_smile:
