Discourse version: 2.5.0.beta4 (e81a4048e3)
When trying to backup, I get the error given below.
[2020-05-16 10:09:19] pg_dump: processing data for table "public.reviewable_claimed_topics"
[2020-05-16 10:09:19] pg_dump: dumping contents of table "public.reviewable_claimed_topics"
[2020-05-16 10:09:19] pg_dump: processing data for table "public.reviewable_histories"
[2020-05-16 10:09:19] pg_dump: dumping contents of table "public.reviewable_histories"
[2020-05-16 10:09:19] pg_dump: processing data for table "public.reviewable_scores"
[2020-05-16 10:09:19] pg_dump: dumping contents of table "public.reviewable_scores"
[2020-05-16 10:09:19] pg_dump: processing data for table "public.reviewables"
[2020-05-16 10:09:19] pg_dump: dumping contents of table "public.reviewables"
[2020-05-16 10:09:19] pg_dump: processing data for table "public.scheduler_stats"
[2020-05-16 10:09:19] pg_dump: dumping contents of table "public.scheduler_stats"
[2020-05-16 10:09:19] pg_dump: Dumping the contents of table "scheduler_stats" failed: PQgetResult() failed.
[2020-05-16 10:09:19] pg_dump: Error message from server: PANIC: corrupted item pointer: 10992
[2020-05-16 10:09:19] pg_dump: The command was: COPY public.scheduler_stats (id, name, hostname, pid, duration_ms, live_slots_start, live_slots_finish, started_at, success, error) TO stdout;
[2020-05-16 10:09:19] Unpausing sidekiq...
[2020-05-16 10:09:19] EXCEPTION: pg_dump failed
[2020-05-16 10:09:19] /var/www/discourse/lib/backup_restore/backuper.rb:183:in `dump_public_schema'
/var/www/discourse/lib/backup_restore/backuper.rb:40:in `run'
/var/www/discourse/lib/backup_restore.rb:184:in `block in start!'
/var/www/discourse/lib/backup_restore.rb:181:in `fork'
/var/www/discourse/lib/backup_restore.rb:181:in `start!'
/var/www/discourse/lib/backup_restore.rb:15:in `backup!'
/var/www/discourse/app/controllers/admin/backups_controller.rb:40:in `create'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/abstract_controller/base.rb:195:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/callbacks.rb:135:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/notifications.rb:180:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/notifications.rb:180:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/abstract_controller/base.rb:136:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionview-6.0.3/lib/action_view/rendering.rb:39:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.0.1/lib/mini_profiler/profiling_methods.rb:104:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_controller/metal.rb:190:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_controller/metal.rb:254:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/routing/route_set.rb:33:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/routing/mapper.rb:48:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/journey/router.rb:49:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/journey/router.rb:32:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/journey/router.rb:32:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/routing/route_set.rb:834:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.8/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.8/lib/rack/conditional_get.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.8/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:318:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.8/lib/rack/session/abstract/id.rb:259:in `context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.8/lib/rack/session/abstract/id.rb:253:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/middleware/cookies.rb:648:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/callbacks.rb:101:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/logster-2.8.0/lib/logster/middleware/reporter.rb:43:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/rack/logger.rb:37:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:18:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.8/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/middleware/executor.rb:14:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.8/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3/lib/action_dispatch/middleware/host_authorization.rb:76:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.0.1/lib/mini_profiler/profiler.rb:312:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-3.2.0/lib/message_bus/rack/middleware.rb:57:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:172:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/engine.rb:527:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.8/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.8/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.8/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.5/lib/unicorn/http_server.rb:605:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.5/lib/unicorn/http_server.rb:701:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.5/lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.5/lib/unicorn/http_server.rb:144:in `start'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.5/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
[2020-05-16 10:09:19] Deleting old backups...
[2020-05-16 10:09:19] Cleaning stuff up...
[2020-05-16 10:09:19] Removing '.tar' leftovers...
[2020-05-16 10:09:19] Marking backup as finished...
[2020-05-16 10:09:19] Refreshing disk stats...
[2020-05-16 10:09:19] Notifying 'RikoDEV' of the end of the backup...
[2020-05-16 10:09:29] Something went wrong while notifying user.
[2020-05-16 10:09:29] Finished!
. I will now check if the backup is successful.
