Could anyone give a database schema dump?
Could you please give a dump of the SQL schema, because my computer cannot install the environment but I really want to know how the database schema is designed (since this project is sooooo famous and wonderful!)
Thanks for the wonderful open-source application!
Hi @fzyzcjy,
Here is the schema: dump.txt (274.1 KB)
Just be aware that most of the “Foreign Keys” are only defined in Ruby, so a pure SQL dump doesn’t give you much to go on.
Some tools, like JetBrain’s RubyMine, can generate a database schema which leverages Ruby relations, which would be better for our use case.
Thank you very much!! I will also have a look at RubyMine if possible :slight_smile:
