Could not resolve host: github.com for SamSaffron/pups.git
Users are experiencing issues with Docker containers failing to resolve github.com during Discourse app rebuilds, despite the host system being able to resolve it. The problem occurs after system updates and is linked to Docker’s DNS configuration and network connectivity. Several users report that using Google’s DNS (8.8.8.8 and 8.8.4.4) in /etc/default/docker does not resolve the issue. One user found that an OVH firewall was blocking traffic to these DNS servers, while others on Ubuntu 18.04 and CentOS 8 face similar problems due to network configuration changes, such as nftables on CentOS 8 or Docker’s default bridge network restrictions. Temporary workarounds include enabling promiscuous mode on docker0 or manually setting up masquerading rules in firewalld. The issue appears to stem from Docker’s inability to access the internet via the default bridge network, with the root cause varying by system configuration. grumps, imaBASKET, gekkonen, rcauvin, and paulraines68 discuss the problem and potential fixes.
Hi all -
We’re enjoying discourse thus far. I’m having an issue with running a rebuild of the docker container. The container won’t rebuild because for some reason it can’t resolve github.com. I know the host system (debian jessie) can resolve at that time via dig && ping. However if I issue a systemctl restart docker the issue goes away.
I turned to the goog or alphabet machine which suggested starting the docker daemon using the goog’s dns which I’ve done and confirmed that it seems to have taken via a systemctl status docker.
I’ve been able to reproduce on a debian droplet and a virtual box vm.
Also I’ve been able to successfully pull a Ubuntu image, and run the container.
I’m not sure if there’s something in launcher or any other suggestions? Working off of git master, and is up to date.
shortlist:
  • Debian Jessie Kernel 3.16
  • Docker version 1.6.2, build 7c8fca2
launch rebuild app
root@alpha:/var/discourse# ./launcher rebuild app
Ensuring discourse docker is up to date
Fetching origin
Discourse Docker is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 10 app
app
cd /pups && git pull && /pups/bin/pups --stdin
fatal: unable to access 'https://github.com/SamSaffron/pups.git/': Could not resolve host: github.com
210c421dbe03e0339d110f1eec9eb3c985b0a0d4e32709d569c9cd1f235a7964
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
systemctl status - shows --dns
root@alpha:/var/discourse# systemctl status docker
● docker.service - Docker Application Container Engine
   Loaded: loaded (/lib/systemd/system/docker.service; enabled)
   Active: active (running) since Thu 2015-08-13 03:42:17 UTC; 26min ago
     Docs: http://docs.docker.com
 Main PID: 22232 (docker)
   CGroup: /system.slice/docker.service
           └─22232 /usr/bin/docker -d -H fd:// --dns 8.8.8.8 --dns 8.8.4.4
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="+job wait(7d602b0addff82e7626b659c5e30131a11ab7f35034198983a19e2b8861111b5)"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="-job wait(7d602b0addff82e7626b659c5e30131a11ab7f35034198983a19e2b88... = OK (0)"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="DELETE /v1.18/containers/7d602b0addff82e7626b659c5e30131a11ab7f3503...8861111b5"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="+job rm(7d602b0addff82e7626b659c5e30131a11ab7f35034198983a19e2b8861111b5)"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="+job log(destroy, 7d602b0addff82e7626b659c5e30131a11ab7f35034198983...e:1.0.12)"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="-job log(destroy, 7d602b0addff82e7626b659c5e30131a11ab7f35034198983... = OK (0)"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="-job rm(7d602b0addff82e7626b659c5e30131a11ab7f35034198983a19e2b8861... = OK (0)"
Aug 13 04:04:15 alpha docker[22232]: time="2015-08-13T04:04:15Z" level=info msg="GET /v1.18/containers/json"
Aug 13 04:04:15 alpha docker[22232]: time="2015-08-13T04:04:15Z" level=info msg="+job containers()"
Aug 13 04:04:15 alpha docker[22232]: time="2015-08-13T04:04:15Z" level=info msg="-job containers() = OK (0)"
Hint: Some lines were ellipsized, use -l to show in full.
docker info
root@alpha:/var/discourse# docker info
Containers: 3
Images: 18
Storage Driver: aufs
 Root Dir: /var/lib/docker/aufs
 Backing Filesystem: extfs
 Dirs: 24
 Dirperm1 Supported: true
Execution Driver: native-0.2
Kernel Version: 3.16.0-4-amd64
Operating System: Debian GNU/Linux 8 (jessie)
CPUs: 1
Total Memory: 2.879 GiB
WARNING: No memory limit support
WARNING: No swap limit support
edit: formatting fix code block
This is very likely the solution
Hi @sam thanks for taking the time to review.
I have that option uncommented in /etc/defaults/docker, and I’ve restarted the docker service many times.
To clarify, after restarting the docker service the laucher rebuild will work once, after that I have to restart the service.
You can see this via my systemd status.
Same issue, I went to add the cloudflare template and when rebuilding it could not resolve github.com.
I have already tried the solution of using googles DNS servers in dockers configuration file with no success.
doing ping github.com works but again, it cant seem to resolve when rebuilding.
Here is the error:
Here is me pinging github.com
Imgur: The magic of the Internet
Interestingly though, when I ping6 github.com I of course do not recieve a response because github does not have AAAA records i believe.
Any idea how to fix this?
This isn’t a Discourse problem, it’s a Docker problem. You’ll probably get more knowledgeable help at the Docker support forums (which, helpfully, also run Discourse).
I figured out the issue and solution to this problem at least for me.
The issue was that Docker uses 8.8.8.8 and 8.8.4.4 as its DNS and I had an OVH network based firewall blocking ALL IPv4 traffic that did not match port 80, 443, and a few other specific rules. I had to authorize IPv4 traffic for 8.8.8.8 and 8.8.4.4
Estoy experimentando un problema similar en la última versión de Discourse desde Git. Esto comenzó a ocurrir después de realizar una actualización del sistema y/o de Discourse a través de la interfaz web. Ahora, cuando intento reconstruir la aplicación, obtengo:
[root@forum /var/discourse]# ./launcher rebuild app
Asegurando que el lanzador esté actualizado
Obteniendo origen
El lanzador está actualizado
Deteniendo el contenedor anterior
+ /usr/bin/docker stop -t 60 app
app
fatal: unable to access 'https://github.com/discourse/pups.git/': Could not resolve host: github.com
8f082ebcb977f9efafbdbff15ab69e8d06c0a7e2cb99410f85e1f90b03ae733b
** FALLO EN EL INICIO ** por favor, desplázate hacia arriba y busca mensajes de error anteriores; puede haber más de uno.
./discourse-doctor puede ayudar a diagnosticar el problema.
Puedo hacer ping a github.com y a 8.8.8.8, y he intentado editar /etc/default/docker para activar la opción DNS: DOCKER_OPTS="--dns 8.8.8.8 --dns 8.8.4.4"
¿Por dónde debería continuar investigando este problema?
Esto es Ubuntu 18.04 con las últimas actualizaciones aplicadas.
Estoy obteniendo el mismo error que gekkonen después de intentar actualizar a la última versión de Discourse.
Parece que Docker ya no puede acceder a Internet en absoluto desde la red puente predeterminada:
docker run -it --net=bridge --rm busybox ping -c 1 github.com
ping: dirección 'github.com' incorrecta
Si lo fuerzo a usar la red del host, puede acceder a Internet:
docker run -it --net=host --rm busybox ping -c 1 github.com
PING github.com (140.82.112.4): 56 bytes de datos
64 bytes desde 140.82.112.4: seq=0 ttl=53 time=6.902 ms
--- estadísticas de ping a github.com ---
1 paquete transmitido, 1 paquete recibido, 0% de pérdida de paquetes
min/avg/max de ida y vuelta = 6.902/6.902/6.902 ms
También estoy ejecutando Ubuntu 18.04.4 LTS, habiendo actualizado todos los paquetes e instalado todas las actualizaciones de seguridad justo antes de seguir la secuencia de actualización de Discourse.
@gekkonen Ya logré que el mío volviera a funcionar. Como solución alternativa, para forzar el funcionamiento de Internet desde Docker, puedes configurar la red docker0 en modo “promiscuo”:
[root@forum /var/discourse]# ifconfig docker0 promisc
Después de eso, deberías poder usar el launcher para reconstruir la aplicación y el foro de Discourse debería funcionar correctamente. La salvedad es que probablemente tendrás que ejecutar el comando nuevamente después de cada reinicio.
Avísame si te funciona.
Aún no conozco la causa raíz del problema.
Sí, eso parece haber resuelto por ahora el problema con el DNS. Gracias por la sugerencia.
En CentOS 8, este error se debe a que los paquetes RPM de Docker para RHEL 7 (aún no existen para RHEL 8) no comprenden el nuevo cortafuegos basado en nftables. Es necesario configurar el enmascaramiento manualmente para la interfaz docker0.
https://serverfault.com/questions/987686/no-network-connectivity-to-from-docker-ce-container-on-centos-8
Me gustaría confirmar que esta solución funciona. Estoy en CentOS 8, con Hetzner.
Para ser específico, ejecuté estos comandos en el orden que se muestra a continuación (fuente) - gracias a @paulraines68
# El enmascaramiento permite el tráfico de entrada y salida de Docker (esta es la parte clave)
firewall-cmd --zone=public --add-masquerade --permanent
# Permitir específicamente el tráfico entrante en los puertos 80/443 (nada nuevo aquí)
firewall-cmd --zone=public --add-port=80/tcp
firewall-cmd --zone=public --add-port=443/tcp
# Recargar el cortafuegos para aplicar las reglas permanentes
firewall-cmd --reload
