I realised that there is an error in our API docs. The active param is only permitted when an API key associated to an admin user is used and has been the case since 2016.
It still doesnāt address the original problem of the message being misleading for admins though.
ā ā curl -X POST -H "api-key: $API_KEY" -H 'api-username: michael' https://try.discourse.org/users.json --json "$(jo email=michael+test@contoso.com username=michaeltest password=$PASSWORD active=true approved=true)"
{"success":true,"active":true,"message":"Your account is activated and ready to use."}
ā ā curl -X POST -H "api-key: $API_KEY" -H 'api-username: michael' https://try.discourse.org/users.json --json "$(jo email=michael+test2@contoso.com username=michaeltest2 password=$PASSWORD active=true approved=true)"
{"success":true,"active":false,"message":"Your account is activated and ready to use."}
^ only a single user was created above
Iām inferring a lot of obfuscation was put into the /users.json path to deter spammers etc. but this seems to be making things difficult for admins as well. I wonder if we should add an explicit admin path to separate the two (normal account creation vs. admin account creation) which will allow the admin function to be unobfuscated.
