Don’t worry dude. I am smart enough to randomly change some characters in it.
And can you specify what i should send in ‘content-type’, as I’ve tried a lot of things.
You will tend to get “BAD CSRF” if your api key has not been supplied correctly. The best way to send it is via HTTP headers. There are more details at the top of our api documentation.
You might need to have correct capitalization for your header keys. So ‘content-type’ needs to be changed to ‘Content-Type’. Same for ‘Content-Length’, but you probably don’t even need to specify that one.
Ohh good, glad you got it working! Yes, sending them in the HTTP headers is the correct way to do it now, but they should still work in the body of the POST. Because I’m trying to improve our error messaging when using the API is there anything you changed as well? Also would you be willing to share the actual node http request code? And how are you using something like querystring.stringify on your payload? Thanks!
Blake, as-tu quelqu’un dans ton équipe d’ingénierie qui pourrait aussi m’indiquer comment faire la même requête avec Node.js ? On peut en parler en MP si tu ne veux pas poster cela dans ce fil Python. Merci beaucoup !
