In the discussion CSS/Feature Help: Ordering Tags Below Topic, LilTrashPanda is seeking help with ordering tags beneath a topic. They want to keep “fixed” and “fix-incoming” tags at the furthest left in the tag space. Falco suggests using CSS to achieve this, providing an initial solution.
LilTrashPanda implements the solution but encounters an issue with the tag’s alignment. Falco offers to help further but needs access to the page. Mittineague suggests using browser dev tools to troubleshoot the issue.
Ultimately, LilTrashPanda finds a solution by adding margin to the CSS rule: .tag-fixed, .tag-fixed:visited, .tag-fixed:hover { background-color: #009900 !important; float: left; margin: -2px 8px 0px 0px; }.
I’m utilizing tags to indicate to members when a fix is incoming or a reported bug/technical issue has been confirmed as being fixed (after the member marks the issue as solved – a bit redundant, but it works for our company’s needs).
I’d like for the “fixed” and “fix-incoming” tags to always be at the furthest left area in the tag space beneath the topic name. Currently, they just seem to go wherever:
Is there any CSS I could use to put that “fixed” tag at the front, always?
Awesome! That worked, however it now looks like the tag is a bit “dropped” compared to the others. Is there anything I can do about that? Perhaps some kind of padding?
You may be able to solve it yourself using your browsers dev tools.
“float” removes an element from the document flow. So any CSS styles that had been previously applied to it - inherited in the cascade - will need to be applied to it in the new “float” rule.
It might not solve everything, but then again it just might.
