Jay_Moore
(Jay Moore)
February 22, 2022, 7:31pm
1
I am trying to pass a custom user field when signing on a user.
Here is the array I am signing…
$parameters = array(
'nonce' => $nonce,
'external_id' => 'jay',
'email' => 'bugsbunny@betaclub.org',
'username' => 'bugsbunny@betaclub.org',
'name' => 'Bugs Bunny',
'add_groups' => 'state_sponsors',
'custom.experience' => 'Pro',
'custom.state' => 'FL',
The field name is Experience, it is a multiselect field and one of the options is Pro
I am not seeing this come across? I also have a custom field named State, which is a Text Field. How do I troubleshoot this. I don’t see anything about the custom field in the logs with discourse connect logging turned on.
Falco
(Falco)
February 22, 2022, 7:40pm
If you have created those fields via the Admin → Customize → User Fields, you need to pass it as
'nonce' => $nonce,
'custom.user_field_1' => 'Pro',
'custom.user_field_2' => 'FL',
The field names aren’t the name you set on the UI, but numbered fields named user_field_NUMBER.
Jay_Moore
(Jay Moore)
February 22, 2022, 8:02pm
3
That worked thanks so much.
Do you know how to populate a multi select field with multiple values?
‘custom.user_field_1’ => ‘Pro, Newbie’,
Falco
(Falco)
February 22, 2022, 8:36pm
4
Curiously I was looking into this last week, and from the looks of it we do not support multi select fields via the DiscourseConnect payload at the moment.
Jay_Moore
(Jay Moore)
February 24, 2022, 12:39pm
7
Did some testing and it will populate a multi select field if only a single value is sent.
Does not work - ‘custom.user_field_1’ => ‘Pro, Newbie’,
Does work - ‘custom.user_field_1’ => ‘Pro’,
This is OK for our needs. If that field is editable by the end user they can add other selections as needed.
@Falco Thanks so much for the help
Jay_Moore
(Jay Moore)
February 24, 2022, 2:16pm
8
Next question is about add_groups. I have a comma delimited list, but it is not adding user to the groups.
'nonce' => $nonce,
'external_id' => $sponsor['spid'],
'email' => $sponsor['email'],
'username' => $sponsor['email'],
'name' => $fullname,
'add_groups' => 'state_sponsor, status_sponsor, elect_sponsor',
'location' => $location,
'custom.user_field_1' => $experience, //experience - Newbie, Less than 5, Pro, Old Timer
'custom.user_field_2' => $club['name'].' ('.$sponsor['new_id'].')', //school name with clubid
'custom.user_field_4' => $division, //division
The payload reported is:
add_groups=state_sponsor%2C+status_sponsor%2C+elect_sponsor
email=xxxx%40spart1.org
external_id=xxxx
name=Angela+Moore
nonce=xxxx
username=xxxx%40spart1.org
location=Landrum%2C+SC
custom.user_field_1=Pro
custom.user_field_2=Landrum+Middle+School+%28JSC0081%29
custom.user_field_4=Junior
In the logs for discouseconnect I see:
add_groups: state_sponsor, status_sponsor, elect_sponsor
admin:
moderator:
avatar_force_update:
avatar_url:
bio:
card_background_url:
email: xxxx@spart1.org
external_id: xxxxx
groups:
locale:
locale_force_update:
logout:
nonce: xxxx
profile_background_url:
remove_groups:
require_activation:
return_sso_url:
suppress_welcome_message:
title:
username: xxxx@spart1.org
website:
Which looks correct.
I would like to add this user to the ‘state_sponsor, status_sponsor, elect_sponsor’ groups.
Falco
(Falco)
February 24, 2022, 5:54pm
9
You need to drop the space between the commas.
system
(system)
Closed
March 26, 2022, 6:01pm
11
