Benutzerdefiniertes Feld funktioniert nicht
Hi All,
I am fairly new to discourse and I am attempting to add a customs field but I am not able to,
Could someone please help me.
My code
after_initialize do
  module ::Foo
  	 PLUGIN_NAME ||= -"discourse-myapi"
     STORE_NAME ||= "replies".freeze
    class Engine < ::Rails::Engine
      engine_name PLUGIN_NAME
      isolate_namespace Foo
  require_dependency "application_controller"
  class Foo::Example
  	class << self
        def bump(id)
           cf_time = Time.zone.now
          DistributedMutex.synchronize("#{Foo::PLUGIN_NAME}-#{cf_time.iso8601}") do
          	user = User.find(id)
            user.custom_fields['signature_url'] = cf_time
            user.save!
            return user
  class Foo::BarController < ::ApplicationController
  	requires_plugin Foo::PLUGIN_NAME
    def custom_field_test
      begin
        user = Foo::Example.bump(1)
        render json: { user: user }
      rescue StandardError => e
        render_json_error e.message
  Foo::Engine.routes.draw do'
    get  '/custom_field_test' => 'bar#custom_field_test'
  Discourse::Application.routes.append do
    mount ::Foo::Engine, at: '/myapiclass'
Thanks
I am going to answer my own question here, since I kind of understand where I was making mistake in terms of my thinking process, and also a benefit of getting feedback from the rest of the team here, as well as for the benefit of new comers to custom_fields functionality in Discourse.
Basically I was making a mistake in thinking without investigation that after I create a custom field on User object by doing
user = User.find(1)
user.custom_fields[“test_field”] = " X X X X"
user.save
I was expecting the custom field to be created on the user object i.e. to become
custome_field_test_field
and I was doing:
user.custom_fields_test_field
But after investigating deeply, I found out that, custom_field is actually an object
user.custom_fields[“test_field”] = { }
and when I do
it appends it to the hash/object
Therefore it becomes
user.custom_fields = {
You also want to add a name to your custom field. The importers all use custom fields, so you could look there for examples.
Hi @pfaffman
Thanks for feedback, but I am not sure if I am following it, could you please give example.
And also on the rails console if I do
[10] pry(main)&gt; user = **User** .find( **1** )
[11] pry(main)&gt; pp user.custom_fields
(2.5ms) SELECT "user_custom_fields"."name", "user_custom_fields"."value" FROM "user_custom_fields" WHERE "user_custom_fields"."user_id" = 1 ORDER BY id asc
{"xxxxxxxxxxxxxxxx"=&gt;"2018-06-16 12:23:39 UTC",
 "test_two"=&gt;"1234567",
 "fountain_cake"=&gt;"2018-06-16 13:16:25 UTC"}
=&gt; **{ **"** xxxxxxxxxxxxxxxx **"** =&gt; **"** 2018-06-16 12:23:39 UTC **"** , **"** test_two **"** =&gt; **"** 1234567 **"** , **"** fountain_cake **"** =&gt; **"** 2018-06-16 13:16:25 UTC **"** }**
I can see the custom fields I added,
But on the plugin:
  begin
     user = User.find(1)
     user.custom_fields['fountain_cake'] = cf_time
     user.save!
    user_after_update = User.find(1)
    json = serialize_data(user_after_update, UserSerializer, root: false)
    render json: { user: json }
It returns the custom_fields as empty object, any thought ?
Look in scripts/import_scripts at any importer to see how they create custom fields.
@pfaffman thanks for let me know about the necessary of adding importers for custom field I am looking into them,
On the second part of the question, do you know if Redis caches requests, when you call the DB from rails application ? because at the moment I am two distinct results, calling via the controller and directly to the database via rails console.
Thanks
Anybody know how I can make the “custom_fields” on User visible ? at the moment when I fetch user object I am getting the custom_fields property is empty object/hash - {}.
But if I do user.custom_fields, I can see all the custom fields, however as part of the User object is empty.
Please refer to the code snippet above for more details.
Thanks
For that you have to whitelist those custom fields in either public user custom fields or staff user custom fields site setting according to your need.
@vinothkannans Thanks for reply,
I am new to discourse and I am not sure, when you say - public user custom fields - if you are referring to the UI part of discourse, on JS or the actual Ruby code. could you please elaborate, or point me to an example.
Thanks
I mean you have to add that custom field’s name in admin site setting at the URL /admin/site_settings/category/all_results?filter=public%20user%20custom%20fields like below
Screenshot%20from%202018-06-18%2017-19-35
@vinothkannansThanks so much,
I can see the field returning as part of the API.
Although I would like to know the wiring under the hood as to why you need to whitelist it ?
Thanks
Custom fields may contain sensitive user data. We shouldn’t expose it by default.
is this features work for requirement, I want to see all users in two different categories, “supplier” or “customer”
If i add into customize → User Fields → Filed Type → Dropdown > Add Field Name
Require tick from below two
Options
Supplier
Customer
Can anyone help me for that, Where i can see this report? It is come with > users List
You probably need the data Explorer plugin to get a report.
@vinothkannans . Thanks for replying.
And I have another question about custom fields, I am not able to see the custom_field on Posts object, nor I can whitelist it on the ui admin page, can you help with this,
Thanks
You should manually add it from a plugin using add_to_serializer(:post, ... method.
@vinothkannans Thanks for suggestion, and it’s working.
One more thing I would like to ask you is, I am trying to set an object as in a JSON object into the custom field, However, when I se it, is setting it as a string with character escapes, is there a way to handle this.
Thanks
JSON.parse(post.custom_fields["FIELD_NAME"])
You can use above command to convert the string to JSON object.
Thanks @vinothkannans
Last question, do you know if is possible in Discourse, to intercept a response from POST request, modify the body, e.g. add a custom field before sending to the client ?
Thanks
Yes, it’s possible. You should go through to the available methods in plugin/instance.rb file. You can also check existing plugin codes to learn about how they handling different situations. And go through Developing Discourse Plugins - Part 1 - Create a basic plugin.
Edit: You can also monkey patch controller methods.
