Hello, I need help. Does anyone know how I can separate the header bar to get the social network icons to move to the upper right where the image that says: Immiland lo tiene todo?
Hello Maria,
Since it appears to be a customized header, it would be convenient if you could share your forum’s URL so we can see the HTML code. ![]()
But at first glance, there is no easy way, it would require some handcrafted javascript to move the custom header links somewhere else.
Sure, my URL is: https://comunidad.immilandcanada.com
