Custom Wizard Plugin šŸ§™
Here’s the plugin, and the create topic category feature, working for me:
AH, I see why now.
I kept getting confused with how the boxes remove what I had set, but did save them. However, this doesn’t apply to all the settings. They’re oddly funky. My video should explain it.
I have the issue with groups and tags. It’s probably affecting other fields as well.
Thanks guys, that’s helpful. A potential fix has been merged. Let me know how you go.
It works for the category setting, but tags still are not set or the selection of tags is just discarded once saved.
Angus, thank you for responding and taking my suggestion in a positive light. I really appreciate all the work you’ve put into this.
The issue with this particular plugin is that some of us use it with users who have just registered. If the plugin doesn’t work for days or weeks, it directly hinders access to our forum. That literally forces us to deactivate it, breaking our curated registration process.
I don’t really know how many reports there were, and it’s not my place to investigate that—you know better than anyone. My point is that, given the plugin’s importance to the site (it can literally prevent new registrations), it might be a good idea to reach out and see if anyone is willing to contribute and help maintain it.
Fortunately, there’s plenty of capacity on Meta, and there’s always someone willing to help out, especially with features as important as this one.
Best wishes.
