Customizing create topic form to add more custom fields, what does add_to_serializer or register_custom_field_type do?
AI 生成的摘要
Customizing Create Topic Form
The discussion revolves around customizing the create topic form in Discourse. net_deamon wants to remove the category option and add custom fields to the form. They were able to add a custom field using the composer-fields-below plugin but are struggling to integrate it with the topic and save the custom field value when the user clicks the “+ Create Topic” button.
net_deamon also discovered the register_custom_field_type method but is unsure how to use it to pass the custom field value to the backend. They are seeking documentation and clarification on what add_to_serializer and register_custom_field_type do.
codinghorror mentions that removing the category option might have negative effects on mobile, but since it’s being replaced with another field, there should be room in the UI.
net_deamon is aware of the potential UI issues and can adjust the height of the create post box to accommodate more custom fields. However, they still need help figuring out how to pass the value from the custom field to TopicCustomField.
Hi I was looking into customizing create topic form.
  1. Removing the category option all together
  2. Adding custom field to the form.
Now I was able to add custom field using the plugin outlet composer-fields-below,
but how to integrate it with topic ? When the user clicks on “+ Create Topic” button, how to save the custom field along with the form?
Then I came to know about
User.register_custom_field_type(‘see_signatures’, :boolean)
in discourse-signatures/plugin.rb at master · xfalcox/discourse-signatures · GitHub.
I tried doing
Topic.register_custom_field_type(‘custom_field’, :string)
But no result.
I just dont know how to pass the custom field value to the backend .
I tried browsing many discourse plugin in github, but could not understand.
what does add_to_serializer or register_custom_field_type do? Can you point me to its documentation?
4 个赞
This is going to have bad effects on mobile, though if you are removing category and replacing it with another field, there should be room in the UI at least.
1 个赞
I can change the height of create post box to include more custom fields.
But I am not able to figure out how to pass the value from custom field to TopicCustomField.
I tried browsing many plugins of discourse in github. Discourse-tagging ( depreciated) is the closest one that matches. I have posted snippet of that code in the question, … How do we pass the value from handlebar template to discourse topic?
