Data Explorer 查询以识别信任级别变更日期
We would like to welcome users when they achieve trust level 3. (We would monitor this periodically through a Data Explorer query.)
Does the database contain information on when a user’s trust level changes?
Or only what the user’s current trust level is?
Thanks,
Randy
3 个赞
Yes, the group_users created_at field can be used for that. It will be set to the date when the user was added to the group. You could try running a query like the one below at periodic intervals to find all users who were added to the group during the interval. The query’s granted_at field expects a date in the form yyyy-mm-dd. For example 2020-09-15
--[params]
-- string :group_name = trust_level_3
-- date :granted_at
SELECT
user_id,
gu.created_at::date
FROM group_users gu
JOIN groups g
ON g.id = gu.group_id
WHERE gu.created_at::date >= :granted_at
AND g.name = :group_name
If you need more user details, it would be possible to update the query to join the users table, or the user_emails table.
4 个赞
This works perfectly, @simon.
Thanks so much!!!
3 个赞
您好 @Randy_Hulett,这个查询可以在哪里找到?我想监控达到 TL2 和 TL3 的用户,但似乎找不到相应的查询。
如果您加入 groupsgroup_users 表,如 @simon 所示,您可以将以下内容添加到 WHERE 子句中:
WHERE gu.created_at::date >= :since
    AND g.name = 'trust_level_3'
    AND u.admin = false
3 个赞
