The discussion revolves around debugging issues when adding a custom LLM to the Discourse AI plugin. Isambard encounters an “Internal Server Error” when testing a model, despite being able to access /v1/models via curl. The issue is initially suspected to be related to special characters in the model name or incorrect URL formatting. Falco suggests adding /v1/chat/completions to the endpoint URL, which resolves the problem for some users. Isambard continues to face errors when testing a local model at http://172.17.0.1:8081/v1/chat/completions, and upon checking logs, discovers a NameError related to an undefined tokenizer. Isambard suspects the issue may be model format-related, as a self-quantized model works. Isambard also asks about integrating the DeepSeek API, with Lilly pointing to a related discussion on the meta forum.
I’m trying to add a custom LLM to Discourse AI plugin. When I press the ‘test’ button I get “Internal Server Error”.
Is there a way of debugging this or getting a better error message? When I go into the docker image and curl the /v1/models, I’m able to fetch this correctly.
The model name is “models/Meta-Llama-3-8B-Instruct.Q6_K.gguf” and I’m not sure whether there could be any issue with special characters.
This was the issue. Note that in LLM software, it is customary to include only upto the /v1 as the endpoint URL. Selection of /chat/completion etc. is then normally added by the software.
NameError (undefined local variable or method 'tokenizer' for an instance of DiscourseAi::Completions::Dialects::ChatGpt) app/controllers/application_controller.rb:424:in 'block in with_resolved_local
Hmm. The one that works is for a model that I quantized myself. I’ll try to quantize the others to see if it is a model format issue.
