Avatares de letras padrão não podem ser vistos
hello,
default letter avatars can not be seen.
When i go to avatar link i get 404 error.
What is the problem.
Thank you in advance.
i added a url in default avatars setting and then reset this setting and problem fixed.
I had the same problem last night. I power cycled my server and it fixed it. Your way sounds easier
You don’t need to do that. Just rebuild your Discourse via SSH, or restart the container.
I think restarting the server (via command line) was faster than rebuilding. And I never remember the command to restart the container.
It’s how I fix my servers at work too
