Delete Post from a Topic Using discourse API
Deleting a Post from a Topic Using Discourse API
User143 is trying to delete a specific post from a topic using the Discourse API. codinghorror suggests reviewing the topic “How to reverse engineer the Discourse API” for details. watchmanmonitor provides links to relevant resources, including a GitHub file with API routes.
User143 attempts to use the destroy_many endpoint with an HTTP POST request, but it doesn’t work. cpradio advises that the correct approach is to use a DELETE request with the post ID in the URL, like http://discourse.url.com/posts/1314, and passing in the API key and username.
To delete a post, use the DELETE method with the post ID in the URL, along with the API key and username.
Is it possible to delete post from a Topic using Discourse API?
Corresponding user can only delete their POST.
Yes, if you can do it with the UI, you can do it via the API call. See the howto topic here titled “How to reverse engineer the Discourse API” for details.
@User143 Review this topic:
and and this text file specifically
https://github.com/discourse/discourse_api/blob/master/routes.txt#L71-L78
I reviewed with this topic but i need to delete particular post from a topic.
I just tried with the following HTTP post but its not working
http://discourse.url.com/posts/1314/destroy_many/?api_key=test_beabcf136e&api_username=test_name
For delete we need to use this URL.Is it right?
destroy_many_posts DELETE /posts/destroy_many(.:format)
I don’t have any clear picture about this API URL. Can you please give the example for deleting the post
When I delete post from chrome using the delete button. I am getting the following header from chrome but i don’t know how can i call this DELETE post API
Remote Address:120.80.217.8:80
Request URL:http://discourse.url.com/posts/1314
Request Method:DELETE
Status Code:200 OK
Look at it the info from Chrome again.
Request URL: http://discourse.url.com/posts/1314
The URL is the key here. It is accessing post id 1314. Now look at the Method
Request Method: DELETE
It is using DELETE, instead of POST, GET, etc.
Combine the two and it will delete the post (so long as you also pass in the API_KEY and API_Username
