It seems possible to add a custom menu through admin->Customize->css_html section.
This menu must be localized. If I can find out the chosen language from the page, I can chose the correct translation for the menu.
Hi @simon, indeed your plugin is great. I gave it a try on my dev instance (v1.5.0.beta8 +164) and it was fantastic!
I found out about the new plugin API.
Indeed, it woud be great to be able to use the plugin with newer Discourse versions. Your help/guidance will be appreciated.
