I’ve been having some fairly consistent trouble with the Discourse development server throwing the following error message, which appears to kill the server pid.
WARNING: V8 isolate was forked, it can not be disposed and memory will not be reclaimed till the Ruby process exits.
It’s not so big a deal to need to restart the server now and again, but it seems to happen fairly regularly on my machine during development. Any steps to avoid this, or a way to turn it off in development mode?
Oh, hm. Looks like it’s picking up ‘thin’ as the default rails server (I’m just running bundle exec rails s from the project root; can’t be bothered with a Vagrant or anything)
Haven’t noticed this over the past couple days using Puma. I see Discourse includes both thin and puma in the Gemfile; does it make sense to either run both with the same server, or specify Puma as the default app server using Rack::Handler.pick or something similar?
Note: one thing that dropping thin did bring up is that our silencer middlewares were not thread safe. That got super annoying in dev mode cause logs would keep getting disabled.
