השבתת letsencrypt נכשלה והפעלת discourse-setup קיבלה התראה חריגה
I try to reconfig about ssl certificate, want to disable letsencrypt free certificate.
Because I have a purchase certificate, I found some operations through Google.
Modify app.yml directly and confirm key & cer in the /var/discourse/shared/standalone/ssl/
and file name are consistent with config file, then rebuild I get the result is failed still use letsencrypt cer
nginx have some error log :
2021/09/25 16:37:26 [emerg] 48#48: cannot load certificate "/shared/ssl/ssl.crt": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/shared/ssl/ssl.crt','r') error:2006D080:BIO routines:BIO_new_file:no such file)
2021/09/25 16:37:27 [emerg] 78#78: cannot load certificate "/shared/ssl/ssl.crt": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/shared/ssl/ssl.crt','r') error:2006D080:BIO routines:BIO_new_file:no such file)
2021/09/25 16:37:28 [emerg] 80#80: cannot load certificate "/shared/ssl/ssl.crt": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/shared/ssl/ssl.crt','r') error:2006D080:BIO routines:BIO_new_file:no such file)
2021/09/25 16:37:29 [emerg] 82#82: cannot load certificate "/shared/ssl/ssl.crt": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/shared/ssl/ssl.crt','r') error:2006D080:BIO routines:BIO_new_file:no such file)
2021/09/25 16:37:30 [emerg] 95#95: cannot load certificate "/shared/ssl/ssl.crt": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/shared/ssl/ssl.crt','r') error:2006D080:BIO routines:BIO_new_file:no such file)
2021/09/25 16:37:31 [emerg] 104#104: cannot load certificate "/shared/ssl/ssl.crt": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/shared/ssl/ssl.crt','r') error:2006D080:BIO routines:BIO_new_file:no such file)
2021/09/25 16:37:32 [emerg] 106#106: cannot load certificate "/shared/ssl/ssl.crt": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/shared/ssl/ssl.crt','r') error:2006D080:BIO routines:BIO_new_file:no such file)
Have confirm file in the directory
root@discourse-test:/var/discourse/shared/standalone/ssl# ls -al ssl.*
-rw-r--r-- 1 root root 7868 Sep 25 16:24 ssl.cer
-rw------- 1 root root 1675 Sep 25 16:24 ssl.key
And found some discussion in following url :
Removing Let’s Encrypt from installation choice
When I run ./discourse-setup I get the alert :
./discourse-setup: line 471: [: 1234567890123456: binary operator expected
Have any suggest to disable letsencrypt or resolve reconfig problem?
There are some topics about how to use your own certificate. You can try searching, but this niche be it Advanced Setup Only: Allowing SSL / HTTPS for your Discourse Docker setup
Hi pfaffman
Thanks for your reply.
For the information you provided, I already have areference and experiment.
But result is failed, nginx service is can’t read file.
The error message is the description above :
I success change use myself certificate.
I keep using the wrong credential file name, the nginx setting need crt file but I keep install and test cer file.
so, I sloved ssl problem.
Thank you
Something that stood out in your first couple of posts was
and
Notice the difference after /shared/ part of the paths. Nginx was expecting the ssl.crt file to be in the shared/ssl/ folder. You found it in shared/standalone/. The file wasn’t in the path where nginx was looking for it.
@JimPas Thanks for your reply
I provide info the path not match. because one path is docker volume path other one is real server file path.
volumes:
  - volume:
      guest: /shared
seems not match, but in fact is same.
the first problem, I was resolve.
root case for me is I didn’t notice certificate format.
config is settings crt format, but I always use cer format file so nginx not success read certificate file.
:man_facepalming:
I never noticed that. Well, slap my wrists!
Glad you realized it and got it fixed. :+1:
