¿Desactivar el atajo de teclado Ctrl+Enter para enviar publicación?
Was just a few lines into a reply on another Discourse site, and I managed to fat-finger something that submitted my post.
Did a bit of testing and seems like Ctrl+Enter would have been the culprit.
Is there any way to turn this off in user preferences?
This is quite standard on most sites as a submit keyboard shortcut. For example on Twitter:
You might be able to override it with some custom JavaScript.
No way, my first question on here is answered by the Jeff Atwood!
Anyway, I know what you mean, with the shortcut being in Outlook, Gmail, all over the place… I just normally disable it :slight_smile:
But no worries, I’ve got my answer about the Discourse functionality, will look into custom solutions if it starts to bother me too much.
Thanks for the great platform @codinghorror!
