Discourse Azure AD Plugin not working
I couldn’t make the Azure AD plugin configured.
https://github.com/discourse/discourse-azure-ad
After adding to app.yml, rebuilding doesn’t work.
Is the plugin obsolete?
Why would you leap straight to the plugin being obsolete?
Define “doesn’t work”. The full console output from the rebuild run would be preferred.
As I couldn’t find the plugin in the meta, I assumed it to be obsolete. :slight_smile:
I added the plugin to app.yml like below
 hooks:
  after_code:
- exec:
    cd: $home/plugins
    cmd:
      - git clone https://github.com/discourse/discourse-azure-ad.git
During the rebuild it fails at the below point.
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 16835 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
4c8dc9092f38bca99f21fac1c7e417f07d979e48f466259088937d1f02345087
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Yeah… we are going to need that :wink:
Sorry for being late to reply. It’s Yesterday that I was look into the discourse configuration again.
Finally I was able to configure it successfully. Seems like I have done a silly mistake when configuring the plugin. I have not properly added the environment variables to app.yml.
Everything seems to be working smoothly now. :smiley:
May I know why it’s not published in the meta as a plugin yet?
Cheers
Hi Chanka
Can you please explain a little more what you did to get it to compile? I can’t get Discourse rebuilt with the plugin in my app.yml file.
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
Thanks!
  • Ryan
Hi Ryan
Before rebuilding you need to
If you’re running Discourse from the Docker container, add these environment variables to your container’s yml file:
DISCOURSE_AZURE_CLIENT_ID
DISCOURSE_AZURE_CLIENT_SECRET
(optional) DISCOURSE_AZURE_TITLE
Cheers
Chanka
Thanks, Chanka! Can’t believe it’s that easy. :slight_smile:
Followup question for @Chanka_Dod and @sam: The oAuth plug-in is working great, except one thing: The user’s email address is incorrect. The plug-in is populating the email address as the short name and the Active Directory domain, neither of which are correct. Example my email address is r-nix@mycollege.edu but the oAuth plugin is making the email address rtn456@ad.mycollege.edu. Is there a way to add something to the code that populates the user account as the ‘mail’ attribute in LDAP or Active Directory.
I am not sure exactly what changes are needed would appreciate some help:
The implementation now is all here:
The gem itself that implement the bridge is here:
https://github.com/KonaTeam/omniauth-azure-oauth2
So you need to figure out first if the change is required in the library we are leaning on vs the library we control.
Crosspoting from gitub. I’m not in a position to test this out at the moment, however it appears that we’re just grabbing the ‘email’ attribute returned from Azure.
line 52 of
Looks like the UPN or UserPrincipalName is the attribute being used as the email address in Discourse. I’ll log a ticket with Azure support to see how this can be fixed. @sam @marknadig
