Discourse-custom-app-banner
If you have a custom Discourse app or maybe an app for your company, you might want to show a custom app banner to your users. Discourse only has the ability to refer people to the Discourse app using the Other → native app install banner site setting, like this one:
afbeelding
The discourse-custom-app-banner allows you to configure your own iTunes / Android apps and show a banner for those instead.
The plugin can be found at GitHub - communiteq/discourse-custom-app-banner
This plugin was developed for RZIM Connect and @outofthebox was so kind to allow us to open source it.
Richard, I’m grateful for your professionalism, speed, and expertise on the Discourse platform.
This plugin provides our members with a better experience. Thank you!
I’m also grateful that you wanted to share this plugin with the Discourse community, which speaks to your character and loyalty. I am very happy to be able, through your hard work, to contribute a tiny bit back to this outstanding product and community.
I think it’s very reasonable to merge this functionality into core.
Two hidden site settings, that allow you to input android_app_id and ios_app_id and default to the current values.
I thought about doing this way, but back then there was just one Discourse app :wink:
Agreed, this is totally fine to merge in. We do not want to forcefully tie people to the one app, that’s not intentional.
Just a quick howto for people trying to use this plugin. The functionality is now in core.
There are two hidden site settings: ios_app_id and android_app_id.
In order to set these, open a rails console and enter
SiteSetting.ios_app_id = XXX
SiteSetting.android_app_id = YYY
where XXX and YYY are the respective app ID’s.
Then you can enable the native_app_install_banner_ios and native_app_install_banner_android settings from within the Admin - Settings screen.
