Discourse Math Editor
The discussion revolves around the Discourse Math Editor plugin, a tool enabling users to input math equations using LaTeX in a user-friendly way. spirobel introduced the plugin, which integrates with MathLive and recommends using KaTeX for speed. Installation instructions are provided, along with links to documentation and a video demo. The plugin requires the official Discourse Math Plugin and has compatibility issues with newer Discourse versions, as noted by Mark_Wass and kuaza, who reported errors. Ethsim2 asked about mobile compatibility and whether the plugin is still functional. Bank_Live suggested moving the math editor icon, and spirobel considered integrating graphing features, possibly via the Graphviz plugin. Ed_Bobkov inquired about a virtual keyboard for non-English input, and spirobel explored open-source alternatives like Keyboard.js, though noted typing speed limitations. xiasummer praised the plugin and asked about resource usage. The plugin remains useful, especially for mobile users, but requires updates for compatibility.
Discourse Math Editor is a plugin to enter math equations into Discourse in a more user friendly way. This editor helps you to create LaTeX. Please read on wikipedia about it if you dont know what it is: wikipedia
For more documentation on all the LateX commands that you can use please have a look here: mathlive docs
And please watch the video:
Installation
Follow Install a Plugin
how-to from the official Discourse Meta, using git clone https://github.com/spirobel/discourse-matheditor.git
as the plugin command.
You also need to use the official math plugin together with this:
offical math plugin
I recommend using KateX instead of MathJax, its way faster (at least for me).
Thaaaats it
Wonderful news. Thank you.
Can math editor icon change location?
We can add output to plugin or not.
thanks for the suggestion, it makes sense. I will have a look at it!
do you mean the graph below the box like in the mathlive docs? I think its a good idea, but probably better handled in a different plugin. What do you think about this plugin:
Does it fit your use case?
Yes i mean. Graphviz plugin I’m not sure whether it can display mathematical images or not.
I think from using inspect element on mathlive.io that he is using Plotly javascript graphing library in JavaScript if there is a need for other plotting libraries maybe we can use the graphiz plugin as a starting point and integrate them in a similar way.
I’m not a math person and working with languages, I’m interested, is it possible to create a plugin with google virtual keyboard?
by the way, I found some posts here that people living in other countries can’t type in their native language, because they don’t have a local keyboard with PC or laptop. Of course they can use online keyboards, but it’s smth like a ‘wooden wheel’ in a new auto .
This is actually something I am interested in as well. I am learning how to create discourse plugins because I want to create a collaborative mandarin dictionary. Its quite a big project, so I am creating these smaller plugins first that have similar features so I can experiment on how to implement the whole thing. We can not use the google virtual keyboard, because it seems like its not an open source library. But a quick google search shows that there are open source virtual keyboard solutions: for example I just came across this one: Virtual Keyboard
I think the big downside of these keyboards is that the typing is very slow. So usually if I want to type in a different language I install something like unikey for vietnamese for example or sunpinyin for mandarin. I expect that most of my users will be able to type in their language so I am not planning to add a virtual keyboard. But I also want to have a way to input pinyin and zhuyin with tones. I still havent figured what to do about this. Which languages are you working with?
This is very beautiful!
Can this be done? Will it cost much hardware resource?
@spirobel I just installed your plugin and now I’m getting this error. Any chance you will be updating your awesome plugin?
Error: the 'matheditor-modal' modal needs updating to work with the latest version of Discourse. See https://meta.discourse.org/t/268057.
This plugin needs to be updated. It causes errors in the editor area.
Hi Spirobal,
your plugin is very useful, particularly for mobile devices.
There has been the many discourse updates since Apr 2024, and i haven’t seen this plugin topic be marked as “broken”, so i assume the above faults weren’t reproducible on later discourse releases?
has anyone had any success with this on smartphone recently?
