אייקון / אימוג'י לפריט ניווט בדיסקורס
סיכום מבוסס בינה מלאכותית
The discussion revolves around the “Discourse Nav Item Icon / Emoji” theme component, which allows users to add icons or emojis before navigation items in Discourse. Don introduced the component, detailing its syntax for icons (icon:nav-item:icon-set:icon-name:icon-color) and emojis (emoji:nav-item:emoji-set:emoji-name:filter), with examples and screenshots demonstrating its use in desktop and mobile views Don. Davidkingham asked about compatibility with FontAwesome Pro, to which Don responded that it’s possible but requires modifying the component with SVGs and considering legal usage. Sheng_hualuo reported that the icon didn’t display on mobile after a Discourse update, and Lilly confirmed the issue in the dropdown navigation. Aaron_Walsh humorously noted the absence of a “follow-on” feature. Don acknowledged the issue, explaining that a recent Discourse update broke compatibility and that the desktop navigation version was removed in a fix to support the new mobile navigation Don. Sheng_hualuo expressed disappointment over the removal of the desktop version, highlighting its visual appeal.
Install this theme component
Hello :wave:
With this theme component you can add icon or emoji before nav items. The theme component based on Discourse Easy 'SVG Icon' and 'Emoji' in CSS.
nav item prefix
This setting can handle the icons and emojis too.
The rule you have to follow is:
Icon
If you want to add icon before a nav item:
First you have to define the type which is icon if you want to add icon before the nav item.
  • nav-item: latest, hot, new, unread, categories etc…
  • icon-set: brands, regular, solid
  • icon-color: currentColor, HEX or color variable
For example:
icon:latest:solid:rocket:currentColor
icon:top:regular:star:var(--gold)
icon:unseen:solid:compass:#228C22
icon
Emoji
If you want to add emoji before a nav item:
First you have to define the type which is emoji if you want to add emoji before the nav item.
  • emoji-set: apple, google, twitter, win10, google_classic, facebook_messenger
  • filter: It makes the emoji color black in light mode and white in dark mode. If the emoji hovered or active it will be reveal with a transition. (optional)
    emoji-filter
For example:
emoji:latest:twitter:rocket:filter
emoji:top:google:star
emoji:new:facebook_messenger:bell
Desktop Navigation
emoji
Mobile Navigation
9 לייקים
Very cool Don, any hope of getting this to work with FontAwesome Pro? I use light icons…
לייק 1
Yeah, I think that’s possible but unfortunately I don’t have access to pro icon set. It works with icon svg so if you access to this than it should work. It requires to modify a little bit the component and add these SVGs. After that you can use it with the settings. And also important what is the legal usage of the pro icons svg on website what I am not sure.
2 לייקים
Why isn’t there a follow-on discourse :rofl: ? Every topic you create, I want a notification!, as the term calls it…YOU SMASH IT!
לייק 1
After updating Discourse, the mobile terminal does not display the icon, which causes confusion,Is there anyone in the same situation as me??
That looks like desktop view in your screenshot (judging by the hamburger icon in left corner), but the component is working for me in mobile. :thinking:
I agree with what @sheng_hualuo is saying about the new navigation (dropdown); it doesn’t appear.
oh I see it in the drop down too. :thinking:
Yeah, sorry this theme component and my others too which modified the navigation bar has to an update since this change DEV: replace list control nav dropdown with DMenuMobile (#28324) · discourse/discourse@931485b · GitHub. I will thinking of a solution. We can target easily the nav items in modal but the selected has no specific class unfortunately and I think we have to drop the desktop navigations from components.
4 לייקים
Hello :wave:
I’ve made an update to this component.
  1. removes desktop navigation version on mobile
  2. adds compatibility to the new mobile navigation
Unfortunately we can’t add here as this section has not a nav item specific class.
Screenshot 2024-08-19 at 19.52.18
https://github.com/VaperinaDEV/discourse-nav-item-icon-emoji/pull/1
2 לייקים
Thank you very much for the fix, but I am very sorry that the desktop version feature was removed, because it looks great with my website
2 לייקים
