Discourse Poison Fountain
:information_source: Summary Add hidden links to content which can poison web scrapers that do not play nice.
:hammer_and_wrench: Repository Link https://github.com/elmuerte/discourse-poison-fountain
:open_book: Install Guide How to install plugins in Discourse
Features
To every generated page it will add links to pages with poisoned content. If a bad web scraper consumes this content and uses it to train a LLM it will negatively affect the resulting model.
These links are hidden for users, they are marked with rel="nofollow" and by default the robots.txt will tell web spiders to not consume this content. The hidden links are only added for non-authenticated requests.
The plugin by default uses the poisoned content from RNSAFFN. See that page for some more information. You can change the poison source in the settings.
The poisoned content is served from pages with URLs like with /dpf/<some-random-slug>/<id>. With the default configuration you could create a fail2ban rule on that path for IPs which request pages from /dpf/ a few times to fend of bad scrapers.
Configuration
You only need to install and enable the plugin for it to start doing its thing in the background. Can you tune some additional settings.
Settings
Include a table of settings and setting descriptions
Name Description
poison_fountain_source The website which generates the content which will be served from the poisoned pages.
poison_fountain_textual_only Only accept textual content from the poison source. This will prevent serving binary content.
poison_fountain_force_plain_text Always serve the content as text/plain even if the source said it some something like, like HTML.
poison_fountain_update_robots_txt Enabled by default, this will add the poisoned content to the exclusion list. Web spiders which respect robots.txt would completely ignore the poisoned content.
poison_fountain_cache_hours Hours to cache the content before retrieving new content. Maximum of 24 hours.
poison_fountain_entries Number of poisoned entries to keep around
poison_fountain_link_count Number of links to add to the generated HTML pages
This project is not affiliated with RNSAFFN. It provides an integration with their service. This integration can be configured to use an other similar working service.
You should realize that by using this plugin you will be trusting the content that is generated by the used poison fountain, and that you are forwarding it. By default this plugin will try to make this content “mostly harmless”, serving only textual content as plain text.
I like this idea. thanks for sharing.
Here’s the robots.txt file that cludflare uses (appends to your own) (I also put it below)
In case anyone is interested in such things :slight_smile:
# As a condition of accessing this website, you agree to abide by the following
# content signals:
# (a)  If a Content-Signal = yes, you may collect content for the corresponding
#      use.
# (b)  If a Content-Signal = no, you may not collect content for the
#      corresponding use.
# (c)  If the website operator does not include a Content-Signal for a
#      corresponding use, the website operator neither grants nor restricts
#      permission via Content-Signal with respect to the corresponding use.
# The content signals and their meanings are:
# search:   building a search index and providing search results (e.g., returning
#           hyperlinks and short excerpts from your website's contents). Search does not
#           include providing AI-generated search summaries.
# ai-input: inputting content into one or more AI models (e.g., retrieval
#           augmented generation, grounding, or other real-time taking of content for
#           generative AI search answers).
# ai-train: training or fine-tuning AI models.
# ANY RESTRICTIONS EXPRESSED VIA CONTENT SIGNALS ARE EXPRESS RESERVATIONS OF
# RIGHTS UNDER ARTICLE 4 OF THE EUROPEAN UNION DIRECTIVE 2019/790 ON COPYRIGHT
# AND RELATED RIGHTS IN THE DIGITAL SINGLE MARKET.
# BEGIN Cloudflare Managed content
User-agent: *
Content-Signal: search=yes,ai-train=no
Allow: /
User-agent: Amazonbot
Disallow: /
User-agent: Applebot-Extended
Disallow: /
User-agent: Bytespider
Disallow: /
User-agent: CCBot
Disallow: /
User-agent: ClaudeBot
Disallow: /
User-agent: Google-Extended
Disallow: /
User-agent: GPTBot
Disallow: /
User-agent: meta-externalagent
Disallow: /
# END Cloudflare Managed Content
User-agent: *
Disallow: /lp
Disallow: /feedback
Disallow: /langtest
Sitemap: https://www.crawlstop.com/sitemap.xml
