דיווח Discourse ואינטגרציית Superset
Discourse has reports for admin as table and charts under /admin/reports. It also has Data explorer plugin that can run arbitrary SQLs. I’m wondering if there is integration with Apache superset so that I can visualize those reports there?
Why not? Discourse is just a postgres DB under the hood and I see that Apache Superset has postgres support, so go for it!
If you need help and have budget post in Marketplace
@merefield Thanks for the reply! I’m using hosted discourse, in that case, do I have access to the underlying postgres DB?
No you won’t, ordinarily. You will need to speak to your host service provider.
Got it. Thanks for the response!
