You should start over from scratch and rebuild. Something is deeply wrong with your configuration.
Learned from a PM:
When targeting your (non-cloudflared) reverse proxy:
○ → curl -k https://forum.pivx.org/assets/ember_jquery-07f49b58317ea9292d939348ec0091eb50a9d8aaabd9e86cc074ef5f049918aa.js | wc -c
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
8 575k 8 48746 0 0 73901 0 0:00:07 --:--:-- 0:00:07 73857
curl: (56) GnuTLS recv error (-9): A TLS packet with unexpected length was received.
48746
When targeting your actual server:
○ → curl -k http://192.0.2.100/assets/ember_jquery-07f49b58317ea9292d939348ec0091eb50a9d8aaabd9e86cc074ef5f049918aa.js | wc -c
100 575k 100 575k 0 0 1016k 0 --:--:-- --:--:-- --:--:-- 1017k
589450
Your reverse proxy is broken and you need to fix it. This is not a Discourse problem.
When pointing the cloudflare A record to the normal server IP it doesn’t connect to the site. Only over the reverse proxy. thanks for the assistance thus far.
I’m getting these same errors too, on a fresh install. I have cloudflare for my root domain, but it’s bypassing on the subdomain I’ve installed discourse to https://forum.theopen.institute. I followed the instructions here for running other sites on the same machine.
The strange thing is, each time, I am able to get most of the way through the welcome and installation process before I start getting the ERR_SPDY_PROTOCOL_ERROR responses in console.
t turns out that (in my case at least) the problem was indeed outside Discourse. I had a permissions problem in my /var/lib/nginx/fastcgi folder. chowning back over to my nginx got discourse working.
It sounds like OP’s issue was different, but since the symptoms and error messages were similar I thought I’d post an update for anyone coming through in the future.
My issue is solved, Turns out the reverse proxy was running out of disk space and thus couldn’t process the files.
