Failed to bootstrap (/tmp/add-cloudflare-ips)
Failed to Bootstrap (/tmp/add-cloudflare-ips)
The user GreenOWL encountered an error while rebuilding their Discourse instance, specifically with the /tmp/add-cloudflare-ips script. The error message indicates that the script failed with a return code of 8.
supermathie suggested that the issue might be related to Cloudflare blocking the IP from retrieving its list of IPs. The user attempted to retrieve the list from their local computer and adapt the template to hardcode it instead of retrieving from Cloudflare.
However, Falco advised removing the Cloudflare fronting, which Mr.X_Mr.X opposed, citing concerns about abuse.
The user GreenOWL tried replacing the URL in the cloudflare.template.yml file with a local IP list, but still encountered the error.
supermathie suggested creating a static template, cloudflare-static.template.yml, to hardcode the Cloudflare IP list. However, GreenOWL was able to fix the issue by modifying the cloudflare.template.yml file to use a GitHub-hosted CloudFlare IP list without a trailing slash in the URL.
The user proposes creating a mirror to the CloudFlare IPs website to bypass the block and obtain a fresh list of IPs.
Hello!
I have this error when try rebuild:
FAILED
Pups::ExecError: /tmp/add-cloudflare-ips failed with return #<Process::Status: pid 1484 exit 8>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params "/tmp/add-cloudflare-ips"
9fe8337bb7b8e64abb480bd2527551585759e48df340dc74bb84c67bdf1ee6b2
This error was safe with enable and disable proxy (orange cloud) on CloudFlare :frowning:
Can you scroll up and show the output from above where the /tmp/add-cloudflare-ips command fails?
Done compiling CSS: 2022-03-22 16:54:37 UTC
I, [2022-03-22T16:54:37.832057 #1]  INFO -- : Downloading MaxMindDB...
Compressing Javascript and Generating Source Maps
I, [2022-03-22T16:54:37.874506 #1]  INFO -- : File > /usr/local/bin/discourse  chmod: +x  chown:
I, [2022-03-22T16:54:37.880784 #1]  INFO -- : File > /usr/local/bin/rails  chmod: +x  chown:
I, [2022-03-22T16:54:37.887872 #1]  INFO -- : File > /usr/local/bin/rake  chmod: +x  chown:
I, [2022-03-22T16:54:37.894248 #1]  INFO -- : File > /usr/local/bin/rbtrace  chmod: +x  chown:
I, [2022-03-22T16:54:37.900136 #1]  INFO -- : File > /usr/local/bin/stackprof  chmod: +x  chown:
I, [2022-03-22T16:54:37.907873 #1]  INFO -- : File > /etc/update-motd.d/10-web  chmod: +x  chown:
I, [2022-03-22T16:54:37.912825 #1]  INFO -- : File > /etc/logrotate.d/rails  chmod:   chown:
I, [2022-03-22T16:54:37.917132 #1]  INFO -- : File > /etc/logrotate.d/nginx  chmod:   chown:
I, [2022-03-22T16:54:37.924129 #1]  INFO -- : File > /etc/runit/1.d/00-ensure-links  chmod: +x  chown:
I, [2022-03-22T16:54:37.930083 #1]  INFO -- : File > /etc/runit/1.d/01-cleanup-web-pids  chmod: +x  chown:
I, [2022-03-22T16:54:37.936780 #1]  INFO -- : File > /root/.bash_profile  chmod: 644  chown:
I, [2022-03-22T16:54:37.941664 #1]  INFO -- : File > /usr/local/etc/ImageMagick-7/policy.xml  chmod:   chown:
I, [2022-03-22T16:54:37.949303 #1]  INFO -- : Replacing (?-mix:server.+{) with limit_req_zone $binary_remote_addr zone=flood:10m rate=$reqs_per_secondr/s;
limit_req_zone $binary_remote_addr zone=bot:10m rate=$reqs_per_minuter/m;
limit_req_status 429;
limit_conn_zone $binary_remote_addr zone=connperip:10m;
limit_conn_status 429;
server {
 in /etc/nginx/conf.d/discourse.conf
I, [2022-03-22T16:54:37.952599 #1]  INFO -- : Replacing (?-mix:location @discourse {) with location @discourse {
  limit_conn connperip $conn_per_ip;
  limit_req zone=flood burst=$burst_per_second nodelay;
  limit_req zone=bot burst=$burst_per_minute nodelay; in /etc/nginx/conf.d/discourse.conf
I, [2022-03-22T16:54:37.960935 #1]  INFO -- : File > /tmp/add-cloudflare-ips  chmod: +x  chown:
I, [2022-03-22T16:54:37.961856 #1]  INFO -- : > /tmp/add-cloudflare-ips
--2022-03-22 16:54:37--  https://www.cloudflare.com/ips-v4/
Resolving www.cloudflare.com (www.cloudflare.com)... 104.16.124.96, 104.16.123.96, 2606:4700::6810:7c60, ...
Connecting to www.cloudflare.com (www.cloudflare.com)|104.16.124.96|:443... connected.
HTTP request sent, awaiting response... 403 Forbidden
2022-03-22 16:54:38 ERROR 403: Forbidden.
I, [2022-03-22T16:54:38.130543 #1]  INFO -- :
I, [2022-03-22T16:54:38.146489 #1]  INFO -- : Terminating async processes
I, [2022-03-22T16:54:38.148916 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
2022-03-22 16:54:38.149 UTC [42] LOG:  received fast shutdown request
I, [2022-03-22T16:54:38.150508 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 103
103:signal-handler (1647968078) Received SIGTERM scheduling shutdown...
2022-03-22 16:54:38.155 UTC [42] LOG:  aborting any active transactions
2022-03-22 16:54:38.167 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2022-03-22 16:54:38.171 UTC [46] LOG:  shutting down
103:M 22 Mar 2022 16:54:38.203 # User requested shutdown...
103:M 22 Mar 2022 16:54:38.204 * Saving the final RDB snapshot before exiting.
103:M 22 Mar 2022 16:54:38.213 * DB saved on disk
103:M 22 Mar 2022 16:54:38.214 # Redis is now ready to exit, bye bye...
2022-03-22 16:54:38.228 UTC [42] LOG:  database system is shut down
FAILED
Pups::ExecError: /tmp/add-cloudflare-ips failed with return #<Process::Status: pid 1487 exit 8>
3123cbaef859e04ff382e3194e1745b88ee6e4777de9f0f7b45cb6cf2ac6d757
root@app:/var/discourse#
Cloudflare has blocked your IP from retrieving its list of IPs. You can try again, ask them why, or manage the list yourself.
To fix the immediate problem I would probably retrieve the list from your local computer and adapt the template to hardcode it instead of retrieving from Cloudflare, then get in touch with them.
@RyanK any suggestions on this? our template pulls the lists every build, but this shouldn’t be a problem. I would expect to get 429 rate-limited rather than 403ed if it were
Sorry, for the question, I’m not profi :frowning: How I can added CloudFlare IPs without use this template cloudflare.template.yml? I’m use Discourse Docker on Ubuntu 20.04.
I have the same issue on two separate instances, different IP’s. @GreenOWL what DC are you using?
If Cloudflare is blocking your access and you aren’t familiar enough to manually fix it I deeply recommend removing the Cloudflare fronting.
Opens the hell gates for abusers.
Your hosting provider data center.
Unless you run a community that attracts abusers it shouldn’t be a problem. And running discourse if such a way that your ip isn’t leaked is rather tricky.
Variant 2.
If you can’t help - stop offended users.
Actually the template action can be embeded manually by fetching the CF IPs from another IP. @Falco gave you a solid advice.
Yes, vultr aswell. I guess you should post a ticket to them mentioning its a problem on all their IPs
Check in your yaml the location of the mounted volume.
I try replace url cloudflare.com/ips-v4/, cloudflare.com/ips-v6/ in cloudflare.template.yml to IPs on my server (when hosted ip list).
contents: |
        #!/bin/bash -e
        # Download list of CloudFlare ips
        wget -q https://www.myserver.com/ips-v4/ -O - > /tmp/cloudflare-ips
        echo >> /tmp/cloudflare-ips
        wget -q https://www.myserver.com/ips-v6/ -O - >> /tmp/cloudflare-ips
        # Make into nginx commands and escape for inclusion into sed append command
        CONTENTS=$(</tmp/cloudflare-ips sed '/^$/d; s/^.*/set_real_ip_from &;/' | tr '\n' '\\' | sed 's/\\/\\n/g')
Have this result
I, [2022-03-22T18:49:10.469231 #1]  INFO -- : Downloading MaxMindDB...
I, [2022-03-22T18:49:10.514524 #1]  INFO -- : File > /usr/local/bin/discourse  chmod: +x  chown:
I, [2022-03-22T18:49:10.521050 #1]  INFO -- : File > /usr/local/bin/rails  chmod: +x  chown:
I, [2022-03-22T18:49:10.528727 #1]  INFO -- : File > /usr/local/bin/rake  chmod: +x  chown:
I, [2022-03-22T18:49:10.534748 #1]  INFO -- : File > /usr/local/bin/rbtrace  chmod: +x  chown:
I, [2022-03-22T18:49:10.541288 #1]  INFO -- : File > /usr/local/bin/stackprof  chmod: +x  chown:
I, [2022-03-22T18:49:10.549718 #1]  INFO -- : File > /etc/update-motd.d/10-web  chmod: +x  chown:
I, [2022-03-22T18:49:10.554428 #1]  INFO -- : File > /etc/logrotate.d/rails  chmod:   chown:
I, [2022-03-22T18:49:10.558589 #1]  INFO -- : File > /etc/logrotate.d/nginx  chmod:   chown:
I, [2022-03-22T18:49:10.565929 #1]  INFO -- : File > /etc/runit/1.d/00-ensure-links  chmod: +x  chown:
I, [2022-03-22T18:49:10.571595 #1]  INFO -- : File > /etc/runit/1.d/01-cleanup-web-pids  chmod: +x  chown:
I, [2022-03-22T18:49:10.578243 #1]  INFO -- : File > /root/.bash_profile  chmod: 644  chown:
I, [2022-03-22T18:49:10.583602 #1]  INFO -- : File > /usr/local/etc/ImageMagick-7/policy.xml  chmod:   chown:
I, [2022-03-22T18:49:10.589959 #1]  INFO -- : Replacing (?-mix:server.+{) with limit_req_zone $binary_remote_addr zone=flood:10m rate=$reqs_per_secondr/s;
server {
I, [2022-03-22T18:49:10.592764 #1]  INFO -- : Replacing (?-mix:location @discourse {) with location @discourse {
I, [2022-03-22T18:49:10.601940 #1]  INFO -- : File > /tmp/add-cloudflare-ips  chmod: +x  chown:
I, [2022-03-22T18:49:10.604368 #1]  INFO -- : > /tmp/add-cloudflare-ips
I, [2022-03-22T18:49:10.791696 #1]  INFO -- :
I, [2022-03-22T18:49:10.811681 #1]  INFO -- : Terminating async processes
I, [2022-03-22T18:49:10.813970 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
2022-03-22 18:49:10.815 UTC [42] LOG:  received fast shutdown request
I, [2022-03-22T18:49:10.816541 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 103
103:signal-handler (1647974950) Received SIGTERM scheduling shutdown...
2022-03-22 18:49:10.820 UTC [42] LOG:  aborting any active transactions
2022-03-22 18:49:10.834 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2022-03-22 18:49:10.837 UTC [46] LOG:  shutting down
2022-03-22 18:49:10.877 UTC [42] LOG:  database system is shut down
103:M 22 Mar 2022 18:49:10.896 # User requested shutdown...
103:M 22 Mar 2022 18:49:10.897 * Saving the final RDB snapshot before exiting.
103:M 22 Mar 2022 18:49:10.923 * DB saved on disk
103:M 22 Mar 2022 18:49:10.924 # Redis is now ready to exit, bye bye...
FAILED
7b755fd1f149c4b1bfb984edccf952001a7d97621aba59a111d07784bf39dc78
Try copying the existing cloudflare.template.yml to cloudflare-static.template.yml and replace the top part to make it look like:
run:
  - file:
      path: /tmp/add-cloudflare-ips
      chmod: +x
      contents: |
        #!/bin/bash -e
        cat <<EOF > /tmp/cloudflare-ips
        173.245.48.0/20
        103.21.244.0/22
        103.22.200.0/22
        103.31.4.0/22
        141.101.64.0/18
        108.162.192.0/18
        190.93.240.0/20
        188.114.96.0/20
        197.234.240.0/22
        198.41.128.0/17
        162.158.0.0/15
        104.16.0.0/13
        104.24.0.0/14
        172.64.0.0/13
        131.0.72.0/22
        2400:cb00::/32
        2606:4700::/32
        2803:f800::/32
        2405:b500::/32
        2405:8100::/32
        2a06:98c0::/29
        2c0f:f248::/32
        EOF
        echo CloudFlare IPs:
        echo $(echo | sed "/^/a $CONTENTS")
        # Insert into discourse.conf
        sed -i "/sendfile on;/a $CONTENTS\nreal_ip_header CF-Connecting-IP;" /etc/nginx/conf.d/discourse.conf
        # Clean up
        rm /tmp/cloudflare-ips
  - exec: "/tmp/add-cloudflare-ips"
  - exec: "rm /tmp/add-cloudflare-ips"
Then change your app container to use the -static template instead of the original one.
Don’t leave it like that forever.
I can fix it in cloudflare.template.yml
I’m use GitHub to hosting CloudFlare IPs list and have this error becouse use link with symbol /
        wget https://raw.githubusercontent.com/xxx-cloud/CloudFlare-IPs/main/ips-v4/ -O - > /tmp/cloudflare-ips
        wget https://raw.githubusercontent.com/xxx-cloud/CloudFlare-IPs/main/ips-v6/ -O - >> /tmp/cloudflare-ips
Need url without / this:
        wget https://raw.githubusercontent.com/xxx-cloud/CloudFlare-IPs/main/ips-v4 -O - > /tmp/cloudflare-ips
        wget https://raw.githubusercontent.com/xxx-cloud/CloudFlare-IPs/main/ips-v6 -O - >> /tmp/cloudflare-ips
It’s work :slight_smile:
I think in the perspective need create mirror to CloudFlare IPs website https://www.cloudflare.com/ips-v4 and https://www.cloudflare.com/ips-v6 to get fresh list and bypass block.
