I just ran an update of Discourse to the lastest commit
I get this error Sorry, there was an error upgrading Discourse. Please check the logs below.
I, [2016-12-05T19:41:14.643971 #16055] INFO -- : Writing /var/www/discourse/public/assets/plugin-0abfbdd37216903be8e403a1e9091be83f123713fb7d2f47265a67b44a6085b8.js
rake aborted!
Barber::PrecompilerError: Pre compilation failed for: <div class="modal-body poll-ui-modal" style="overflow: visible">
<div class="details">
<table>
<tbody>
<tr>
<td>{{i18n "poll_ui.poll_name_label"}}</td>
<td>{{text-field id="poll-name" value=controller.pollName placeholderKey="poll_ui.poll_name_placeholder" }}</td>
<td>{{i18n "poll_ui.poll_type_label"}}</td>
<td>{{combo-box name="poll-type" valueAttribute="value" value=controller.pollType
nameProperty="title" content=pollTypes }}</td>
</tr>
</tbody>
</table>
<table>
<tbody>
{{#if isMultipleOrNumberPoll}}
<tr>
<td>
{{#if isNumberPoll}}
{{i18n "poll_ui.poll_min_numeric_label" }}
{{else}}
{{i18n "poll_ui.poll_min_multiple_label" }}
{{/if}}
</td>
</td>
<td class="numeric-field">
{{text-field id="poll-max-value" value=controller.pollMaxValue placeholderKey="poll_ui.poll_max_placeholder" maxlength="3" }}
</td>
</tr>
<tr>
<td colspan="2">{{input-tip validation=minValueValidation}}</td>
<td colspan="2">{{input-tip validation=maxValueValidation}}</td>
</tr>
{{/if}}
<tr>
<td>
{{i18n "poll_ui.poll_step_label" }}
</td>
{{text-field id="poll-step-value" value=controller.pollStepValue placeholderKey="poll_ui.poll_step_placeholder" maxlength="3" }}
</td>
<td colspan="2"></td>
</tr>
<tr><td colspan="4">{{input-tip validation=stepValueValidation}}</td></tr>
{{/if}}
</tbody>
</table>
</div>
<div class="content">
{{#unless isNumberPoll}}
<div {{bind-attr class=":choices choicesClass"}}>
<div>{{i18n "poll_ui.poll_options_label"}}</div>
{{input-tip validation=optionsValidation}}
{{d-editor value=controller.pollOptions}}
</div>
{{/unless}}
{{#if canProvideAnswers}}
<div class="answer">
<div>{{i18n "poll_ui.poll_answer_label" }}</div>
{{d-editor value=controller.pollAnswerValue }}
</div>
{{/if}}
</div>
</div>
<div class="modal-footer">
<div class="pull-left">
<label class='checkbox-label'>
{{input type="checkbox" id="make-public" checked=controller.pollMakePublic}}
{{i18n "poll_ui.poll_make_public_label"}}
</label>
</div>
<div class="pull-right">
<button class="btn btn-primary pull-right" {{bind-attr disabled="submitDisabled"}} {{action "apply"}}>{{i18n "poll_ui.insert_button"}}</button>
</div>
</div>
. Compiler said: Error: Assertion Failed: Using `{{controller}}` or any path based on it ('javascripts/poll-ui' @ L7:C42) has been removed in Ember 2.0
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/barber-0.11.1/lib/barber/precompiler.rb:33:in `rescue in compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/barber-0.11.1/lib/barber/precompiler.rb:31:in `compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/barber-0.11.1/lib/barber/precompiler.rb:8:in `compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/ember-handlebars-template-0.7.4/lib/ember/handlebars/template.rb:166:in `block in precompile_ember_handlebars'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/cache.rb:85:in `fetch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/ember-handlebars-template-0.7.4/lib/ember/handlebars/template.rb:165:in `precompile_ember_handlebars'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/ember-handlebars-template-0.7.4/lib/ember/handlebars/template.rb:89:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/ember-handlebars-template-0.7.4/lib/ember/handlebars/template.rb:39:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:75:in `call_processor'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:57:in `block in call_processors'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:56:in `reverse_each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:56:in `call_processors'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:134:in `load_from_unloaded'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:60:in `block in load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:317:in `fetch_asset_from_dependency_cache'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:44:in `load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/cached_environment.rb:20:in `block in initialize'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/cached_environment.rb:47:in `load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/bundle.rb:23:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/utils.rb:196:in `dfs'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/bundle.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/base.rb:66:in `find_asset'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/base.rb:73:in `find_all_linked_assets'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:134:in `block in find'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:133:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:133:in `find'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:185:in `compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-rails-3.1.1/lib/sprockets/rails/task.rb:68:in `block (3 levels) in define'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/rake/sprocketstask.rb:147:in `with_logger'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-rails-3.1.1/lib/sprockets/rails/task.rb:67:in `block (2 levels) in define'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-11.2.2/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
(execjs):16397:7
Walker.visit ((execjs):23457:7)
ElementNode ((execjs):23473:16)
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:167:in `eval_unsafe'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:167:in `block (2 levels) in eval'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:217:in `timeout'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:166:in `block in eval'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:63:in `block in with_lock'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:63:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:63:in `with_lock'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:164:in `eval'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/execjs-2.7.0/lib/execjs/mini_racer_runtime.rb:27:in `block in eval'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/execjs-2.7.0/lib/execjs/mini_racer_runtime.rb:66:in `translate'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/execjs-2.7.0/lib/execjs/mini_racer_runtime.rb:26:in `eval'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/execjs-2.7.0/lib/execjs/mini_racer_runtime.rb:34:in `call'
MiniRacer::RuntimeError: Error: Assertion Failed: Using `{{controller}}` or any path based on it ('javascripts/poll-ui' @ L7:C42) has been removed in Ember 2.0
JavaScript at new Error (native)
JavaScript at Error.EmberError (<anonymous>:9091:21)
JavaScript at assert (<anonymous>:6024:13)
JavaScript at Object.assert (<anonymous>:8855:34)
JavaScript at assertPath (<anonymous>:16427:22)
JavaScript at assertPaths (<anonymous>:16422:7)
JavaScript at assertHash (<anonymous>:16411:7)
JavaScript at <anonymous>:16397:7
JavaScript at Walker.visit (<anonymous>:23457:7)
JavaScript at ElementNode (<anonymous>:23473:16)
Tasks: TOP => assets:precompile
Bundling assets
