Displaying user custom fields in data explorer query results
A discussion on modifying a Data Explorer query to display user custom fields in the results, initiated by tobiaseigen. LeoMcA agreed to update the query, and tobiaseigen explained that the goal is to include custom fields in a dashboard for monitoring member activity.
LeoMcA provided the modified query, which requires manual addition or removal of lines to match the number of custom fields. The query can be adjusted to fit specific setups. tobiaseigen confirmed that the modified query works perfectly for their needs.
nathank found the query helpful but is seeking a way to automatically include all user data fields, as they have dynamic user fields in a large instance.
Hi @LeoMcA! I love this query of yours that you created last year to use the data explorer to display a chronological list of user topics started, replied and liked. Would you be willing to update the query to also optionally include user custom fields in the results? It would be a big help to me right now. :pray:
Trust all is well. Happy holidays! :night_with_stars:
Sure, should be a pretty trivial change.
I should get it done by the end of next week… hope you can wait until next year! :wink:
Been pretty busy with Uni, but I can’t really complain about that - hope you’ve had a good holiday season too :slight_smile:
That’s great news, thanks Leo! I really appreciate it.
Glad to hear you’re keeping well and busy with school, and enjoying the holidays. All is well on my end. I’m a bit sad to see the end of a nice break from work but am also looking forward to getting back into things at Namati.
I’m working on a dashboard to monitor member activity and get better aggregated statistics on activity across our network, including face to face events, webinars, resource downloads among other things. It’s going to be interesting to be able to include discourse topics started, replied and liked. :rocket:
Here we go:
-- [params]
-- date :date_from = 1970-01-01
-- date :date_to = 2038-01-19
-- boolean :guess_domain = true
-- string :domain = https://example.com
WITH ss AS (
  SELECT CASE
    WHEN :guess_domain = true THEN concat('https://', split_part(value, '@', 2))
    ELSE :domain
  END AS domain
  FROM site_settings
  WHERE name = 'notification_email'
), cfs AS (
  SELECT
    u.id AS user_id,
    MAX(CASE ucf.name WHEN 'user_field_1' THEN value END) AS first_field,
    MAX(CASE ucf.name WHEN 'user_field_2' THEN value END) AS second_field,
    MAX(CASE ucf.name WHEN 'user_field_3' THEN value END) AS third_field,
    MAX(CASE ucf.name WHEN 'user_field_4' THEN value END) AS fourth_field,
    MAX(CASE ucf.name WHEN 'user_field_5' THEN value END) AS fifth_field
  FROM user_custom_fields AS ucf
  RIGHT JOIN users AS U on ucf.user_id = u.id
  GROUP BY u.id
SELECT
  ua.created_at,
  CASE
    WHEN ua.action_type = 1 THEN 'Like'
    WHEN ua.action_type = 4 THEN 'New Topic'
    WHEN ua.action_type = 5 THEN 'Topic Reply'
    WHEN ua.action_type = 12 THEN 'Message'
  END AS action,
  u.username,
  ucf.*,
  t.title AS topic_title,
  c.name AS category,
  pc.name AS parent_category,
  concat((SELECT domain from ss), '/t/', t.id, '/', (CASE WHEN p.post_number IS NOT NULL then p.post_number ELSE 1 END)) AS url
FROM user_actions AS ua
JOIN users AS u ON ua.user_id = u.id
LEFT JOIN cfs AS ucf on ucf.user_id = u.id
JOIN topics AS t ON ua.target_topic_id = t.id
LEFT JOIN posts AS p ON ua.target_post_id = p.id
LEFT JOIN categories AS c ON t.category_id = c.id
LEFT JOIN categories AS pc ON c.parent_category_id = pc.id
WHERE
  ua.user_id != -1
  AND
  ua.action_type IN (1, 4, 5, 12)
  AND
  ua.created_at BETWEEN :date_from AND :date_to
ORDER BY created_at DESC
It’ll require a little bit of modification to your exact setup. Add or remove the series of 5 lines which look like this:
to your exact number of custom fields (if you need more than 5, then add a line with user_field_6, user_field_7, etc.). You can also change first_field/second_field/etc. to a more descriptive name of what the field contains.
So that section, based on what I remember of your custom user fields, might end up looking something like:
SELECT
  u.id AS user_id,
  MAX(CASE ucf.name WHEN 'user_field_1' THEN value END) AS facebook,
  MAX(CASE ucf.name WHEN 'user_field_2' THEN value END) AS twitter,
  MAX(CASE ucf.name WHEN 'user_field_3' THEN value END) AS linked_in
GROUP BY u.id
There’s probably a way to do this automatically, but I’m not enough of a SQL guru to work it out :wink:
Fantabulous. thanks, @LeoMcA! Works perfectly. Really all I want is the wordpress user ID for matching. It’s stored as a custom user field. :rocket:
Ich habe diese Abfrage für unsere Website sehr hilfreich gefunden, aber es hat eine Weile gedauert, sie anzupassen / zu hacken, damit sie nach Gruppen funktioniert, und um weitere Benutzerinformationen wie E-Mails einzubeziehen.
Allerdings stehe ich kurz davor, eine große Instanz mit einigen Benutzerfeldern zu starten, die eine Zeit lang etwas dynamisch sein werden.
Hat jemand da draußen den Durchblick, diese Abfrage so umzubauen, dass sie automatisch alle Benutzerdatenfelder ausgibt? Vielleicht @simon?
Hier ist meine Abfrage im Moment:
–[params]
– string :group_name
With included_users AS (
SELECT
gu.user_id
FROM group_users gu
JOIN groups g
ON g.id = gu.group_id
WHERE g.name = :group_name
e AS (
SELECT email, user_id
FROM user_emails u
WHERE u.primary = true
SELECT
u.id AS user_id, u.username, u.name, e.email,
MAX(CASE ucf.name WHEN ‘user_field_6’ THEN value END) AS “Mobile Phone”,
MAX(CASE ucf.name WHEN ‘user_field_2’ THEN value END) AS “Job Title”,
MAX(CASE ucf.name WHEN ‘user_field_5’ THEN value END) AS “Employer”,
MAX(CASE ucf.name WHEN ‘user_field_4’ THEN value END) AS “Postcode”,
MAX(CASE ucf.name WHEN ‘user_field_14’ THEN value END) AS “Clinical Profession”,
MAX(CASE ucf.name WHEN ‘user_field_3’ THEN value END) AS “Clinical Speciality”,
MAX(CASE ucf.name WHEN ‘user_field_17’ THEN value END) AS “Working Clinically”,
MAX(CASE ucf.name WHEN ‘user_field_1’ THEN value END) AS “Informatics Interest”,
MAX(CASE ucf.name WHEN ‘user_field_15’ THEN value END) AS “Dietary Requirement”
RIGHT JOIN e on ucf.user_id = e.user_id
WHERE u.id IN (SELECT user_id FROM included_users)
GROUP BY u.id, e.email
ORDER BY username asc
