لا تضبط الوقت الحالي كـ "آخر تعديل" عند استخدام صورة افتراضية "غير موجودة"
I’ve just discovered a weird interaction with Akamai’s CDN that may be down to the Last-Modified header… but that’s a guess.
This is a response from Akamai with the “default avatar” cached, it’s doing the right thing and passing along the remaining TTL on the cached item:
HTTP/1.1 200 OK
Last-Modified: Fri, 31 Aug 2018 03:59:15 GMT
Content-Type: image/png
Server: nginx
Content-Length: 2608
Cache-Control: public, max-age=61
Date: Fri, 31 Aug 2018 04:17:29 GMT
After the object expires and we request it from the CDN again it’s re-fetched from origin and now the origin has returned the correct avatar:
HTTP/1.1 200 OK
Last-Modified: Fri, 31 Aug 2018 03:30:06 GMT
Server: nginx
Cache-Control: public, max-age=31556670
Date: Fri, 31 Aug 2018 04:22:07 GMT
Note that now it’s got a max-age of “forever” and the Last-Modified of the file itself… but the Content-Length has not changed. The actual response from the origin directly looks like this:
HTTP/1.1 200 OK
Content-Type: image/jpeg
Server: nginx
Content-Length: 1068
Cache-Control: max-age=31556952, public, immutable
Date: Fri, 31 Aug 2018 04:27:35 GMT
I suspect that because the Last-Modified went backwards in time Akamai got confused and cached the “old” content with the “new” max-age. This is a bug on Akamai’s end which I will address with them.
BUT I do not think we should send the current time as Last-Modified here as it doesn’t affect max-age:
max-age=<seconds>
Specifies the maximum amount of time a resource will be considered fresh. Contrary to Expires, > this directive is relative to the time of the request.
We should omit it entirely or set it to the epoch when we return the default avatar.
إعجاب واحد (1)
Cool, this is now fixed per:
3 إعجابات
