Document generator tool for ES6
I’ve tried many javascript generator tool to generate docs for JavaScript ES6, all of them had problem with new syntax of ES6.
Is there a tested js doc generator to build documentation from Discourse sources?
Not that I know of. But why do you want a documentation of Discourse JS code? If you want to add a feature, I highly recommend that you write a plugin instead.
I want to read the nice looking documentation, there a special formatting in source for that
Finally I got it by http://documentation.js.org/, cool!
