I see that any icon with a gradient that I put doesn’t work, does the Discourse not accept it?
If he doesn’t accept it, is there a way to put a gradient around the icons via css?
I have same queries, anybody have any clue regarding this?
If the SVG format supports gradients, then consider it a bug. Probably best reported as a feature request at the git
repository.
An svg such a logo should work fine.
AFAIK SVG icon gradients are overridden when their color is set by the CSS?
I saw that there are two ways, by CSS and by the code of the SVG file, but whenever I use one or the other it doesn’t work, the file doesn’t change!
Do you know of a way for me to use gradient on the icons?
