האם הקונטיינר של Discourse שלנו צריך להיבנות מחדש?
סיכום מבוסס בינה מלאכותית
A user, hello-smile6, encountered an error while trying to upgrade their Discourse forum from the web UI using the docker_manager plugin. merefield suggested that the issue may be related to the use of Chatbot and provided a link to a relevant post. hello-smile6 asked if it’s possible to run the commands in the after_code section without rebuilding and restarting the container. merefield and merefield advised against it, stating that the container needs to rebuild itself to apply the changes and that manual additions would be lost. Instead, merefield recommended adding the necessary script lines to app.yml to continue using Chatbot.
I just got this error while trying to upgrade a forum from the web UI using the docker_manager plugin, does the container need rebuilt?
*** Please be patient, next steps might take a while ***
Cycling Unicorn, to free up memory
Restarting unicorn pid: 591637
Waiting for Unicorn to reload.
Waiting for Unicorn to reload..
Waiting for Unicorn to reload...
Waiting for Unicorn to reload....
Waiting for Unicorn to reload.....
Waiting for Unicorn to reload......
Waiting for Unicorn to reload.......
Waiting for Unicorn to reload........
Waiting for Unicorn to reload.........
Waiting for Unicorn to reload..........
Waiting for Unicorn to reload...........
Waiting for Unicorn to reload............
Waiting for Unicorn to reload.............
Using rails_multisite 5.0.0
Using raindrops 0.20.1
Using rbtrace 0.4.14
Using rchardet 1.8.0
Using redis-namespace 1.11.0
Using rexml 3.2.6
Using rinku 2.0.6
Using rotp 6.2.2
Using rqrcode_core 1.2.0
Using rqrcode 2.2.0
Using rss 0.3.0
Using rtlcss 0.2.1
Using ruby-readability 0.7.0
Using rubyzip 2.3.2
Using sanitize 6.0.2
Using sshkey 3.0.0
Using stackprof 0.2.25
Using tzinfo-data 1.2023.3
Using uglifier 4.2.0
Using unicorn 6.1.0
Using web-push 3.0.0
Bundle complete! 136 Gemfile dependencies, 172 gems now installed.
Gems in the groups 'development' and 'test' were not installed.
Bundled gems are installed into `./vendor/bundle`
$ yarn install
yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
success Already up-to-date.
$ yarn --cwd app/assets/javascripts $(node -e 'const argv = JSON.parse(process.env.npm_config_argv).original; const passthrough = [`--frozen-lockfile`, `-s`].filter(arg => argv.includes(arg)); console.log(passthrough.join(` `));')
[1/4] Resolving packages...
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
$ patch-package
patch-package 8.0.0
Applying patches...
@ember/jquery@2.0.0 ✔
ember-source@3.28.12 ✔
virtual-dom@2.1.1 ✔
Done in 1.86s.
Done in 2.61s.
$ LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all
discourse-activity-pub is already at latest compatible version
discourse-affiliate is already at latest compatible version
discourse-ai is already at latest compatible version
discourse-akismet is already at latest compatible version
discourse-apple-auth is already at latest compatible version
discourse-assign is already at latest compatible version
discourse-automation is already at latest compatible version
discourse-cakeday is already at latest compatible version
discourse-calendar is already at latest compatible version
discourse-chatbot is already at latest compatible version
discourse-data-explorer is already at latest compatible version
discourse-docs is already at latest compatible version
discourse-footnote is already at latest compatible version
discourse-gamification is already at latest compatible version
discourse-github is already at latest compatible version
discourse-linkedin-auth is already at latest compatible version
discourse-login-with-amazon is already at latest compatible version
discourse-math is already at latest compatible version
discourse-microsoft-auth is already at latest compatible version
discourse-patreon is already at latest compatible version
discourse-reactions is already at latest compatible version
discourse-rss-polling is already at latest compatible version
discourse-shared-edits is already at latest compatible version
discourse-solved is already at latest compatible version
discourse-spoiler-alert is already at latest compatible version
discourse-subscriptions is already at latest compatible version
discourse-templates is already at latest compatible version
discourse-user-notes is already at latest compatible version
discourse-voting is already at latest compatible version
discourse-whos-online is already at latest compatible version
discourse-yearly-review is already at latest compatible version
docker_manager is already at latest compatible version
$ SKIP_POST_DEPLOYMENT_MIGRATIONS=1 bundle exec rake multisite:migrate
Plugin name is 'discourse-topic-voting', but plugin directory is named 'discourse-voting'
1 migrations failed!
Failed to migrate default
#<StandardError:"An error has occurred, this and all later migrations canceled:\n\nERROR:  current transaction is aborted, commands ignored until end of transaction block\n">
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.1.1/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.1.1/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/mini_sql-1.5.0/lib/mini_sql/postgres/connection.rb:202:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/mini_sql-1.5.0/lib/mini_sql/active_record_postgres/connection.rb:38:in `block in run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/mini_sql-1.5.0/lib/mini_sql/active_record_postgres/connection.rb:34:in `block in with_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/mini_sql-1.5.0/lib/mini_sql/active_record_postgres/connection.rb:34:in `with_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/mini_sql-1.5.0/lib/mini_sql/active_record_postgres/connection.rb:38:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/mini_sql-1.5.0/lib/mini_sql/postgres/connection.rb:64:in `query_single'
/var/www/discourse/plugins/discourse-chatbot/db/migrate/20230820010101_enable_embedding_extension.rb:8:in `rescue in change'
/var/www/discourse/plugins/discourse-chatbot/db/migrate/20230820010101_enable_embedding_extension.rb:4:in `change'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:870:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `block in exec_migration'
/usr/local/lib/ruby/3.2.0/benchmark.rb:296:in `measure'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:854:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:853:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/connection_pool.rb:215:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:852:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1046:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1360:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/database_statements.rb:316:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/transactions.rb:209:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1411:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1359:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1333:in `each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1333:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1282:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1432:in `block in with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1447:in `with_advisory_lock_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1428:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1282:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1117:in `up'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1092:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/tasks/database_tasks.rb:262:in `migrate'
/var/www/discourse/lib/tasks/db.rake:196:in `block (3 levels) in <main>'
/var/www/discourse/lib/tasks/db.rake:159:in `block (3 levels) in execute_concurrently'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:82:in `with_connection'
/var/www/discourse/lib/tasks/db.rake:157:in `block (2 levels) in execute_concurrently'
Multisite migrator is running using 1 threads
Migrating default
== 20230820010101 EnableEmbeddingExtension: migrating =========================
-- enable_extension(:embedding)
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:209:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:108:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/commands/runner/runner_command.rb:43:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/command/base.rb:87:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/command.rb:48:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/commands.rb:18:in `<main>'
<internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:37:in `require'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.16.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in `require'
bin/rails:18:in `<main>'
Spinning up 14 Unicorn worker(s) that were stopped initially
Yes, I see you are using Chatbot.
Either omit it or read through this post carefully:
https://meta.discourse.org/t/discourse-chatbot-now-smarter-than-chatgpt/256652/382?u=merefield
Thanks for your patience with this change, it was important to take Chatbot to the next level :rocket:
Can we run the commands in the after_code section without rebuilding and restart the container after?
I don’t believe simply restarting the container will run that section.
Can that be run manually, though?
I don’t think that will work, as the container needs to rebuild itself, even with the online upgrade, so all your nice manual additions would get wiped out.
If you want to continue to use chatbot I would grab the bull by the horns and add the additional script lines to app.yml.
