Maakt SSO gebruik van gescreende IP-adressen om registraties te blokkeren?
The discussion explores whether Screened IP Addresses block registrations in a Discourse site using SSO. cpradio initially questions if SSO bypasses IP blocking, noting that blocked IPs still manage to register. pfaffman confirms that SSO controls logins, so Discourse cannot enforce IP blocks. simon tests this and confirms that SSO does block registrations from screened IPs, as designed. cpradio reports a discrepancy where a blocked IP successfully registered, but simon and riking suggest possible explanations like VPN use or different devices. cpradio speculates the issue may stem from a mismatch between the SSO-provided registration IP and Discourse’s recorded IP.
I think I know the answer to this but wanted to confirm this is expected and not a bug of any sort (I think it is expected).
Sort version, our site uses SSO. The primary website controls registration and authorizes an account in Discourse over SSO. Now, we’ve made sure that we pass forward the user’s IP address in our setup and we can confirm that by looking at each user’s Admin page, however, when we add an IP address to the Blocked list in Screened IPs, it doesn’t block future attempts to create/authorize an account.
My guess is SSO bypasses that check, is that a correct statement, and is that the expected outcome?
Backstory:
The reason why I ask, is our moderation team is doing extra work right now ensuring IP addresses get added to the blocked list for accounts that are extremely disruptive/abusive and have noticed it doesn’t seem to make a difference. So with that said, they are wanting me to investigate if they need to continue doing those steps or can just ignore them (in case the screened ip list serves no purpose to SSO setups).
If sso is controlling who logs in to your site then discourse doesn’t and can’t. I’m pretty sure that there is no benefit in blocking ip on the discourse side since another server controls logins.
Yeah, that is my understanding and impression too (hence why to me this is expected).
I just tested this on my own site. After adding my IP Address to the Screened IPs list and setting its action to “Block”, users are not able to create new accounts from that IP address when logging in via SSO. This is by design. You can see where it happens in the code here: discourse/app/controllers/session_controller.rb at main · discourse/discourse · GitHub.
Interesting… as we definitely have a recent account who’s registration IP was blocked on August 20th, but they successfully created an account on September 15th.
Edited:
But then I also found this in the logs so it seems to work occassionally?
Verbose SSO log: IP address is blocked [ip_address_redacted]
add_groups:
admin:
moderator:
avatar_force_update:
Possibly they were using a VPN, or were on a different computer/mobile device?
With that time gap, they probably didn’t even notice they were bypassing an IP block.
Ah, I think I see what is going on. We have a custom SSO field named registration IP, and that clearly shows the blocked IP address, but the Last IP listed in Discourse is different, my guess, and its purely a guess which might explain VPN usage, but how our registration field got the blocked address and Discourse got a different one is unknown to me.
