The main reason is to allow consent for the unopposed nominee and keep everything centralized to the election topic without having to go elsewhere.
Almost all of the elections involve self-nomination and if oneself nominated person runs unopposed and no one votes for them they still shouldn’t get the position.
What I could add is a feature that allows a mod or admin to identify a ‘winner’ of the election at any stage of the election, i.e. nomination, poll, closed poll. That would also be useful to clarify the outcome of standard (contested) elections.
I am not sure if you’ve heard about this before, but here comes my story, haha. Today I installed your plugin and I experiemented with it. I deleted a thread with an election in it as I was testing the plugin itself, worked well. After I have deleted that thread I ran into a major issue for my website.
As soon as someone replied to a thread, or created a new thread, they would receive an error and the thread would just return a 404 error everytime you tried to access it.
@angus If a user was nominated, then later is anonymized, their name in the election post will remain. Not functional problem but I would expect it to be scrubbed when anonymized.
Now when a user is anonymised, if they have any election nominations those nominations will also be anonymised.
I opted to anonymise the nomination rather than remove it, as removing it would change the nominee count and have other knock-on effects. Retaining an anonymised nomination is consistent with other anonymization behaviour (i.e. anonymised posts are retained).
You can now identify a “Winner” of the election at any stage of the election process in the “Manage Election” modal.
You can only identify one winner.
I allowed identification of a winner in the Nomination and Poll stages, as there may be cases (see above) in which you want to identify a winner without a poll or while polling is going on.
Selecting a winner does not effect the election state, i.e. if you select a winner when the poll is open it will not automatically close the poll.
The Winner is identified under the heading “Winner” at the top of the election post (i.e. the first post). Examples:
Hi! Thanks for this plugin, we’re trying it out for a pseudo election in our organization (board is appointing but asking for input). I had an issue where I used the election interface to start the poll but when people tried to vote it would say “Poll must be open in order to vote.”
I finally figured out that if I put the election back to nominations and then pressed the start poll button, that the election would be truly open. Unfortunately I also sent “this poll is open” system messages 5 times trying to figure it out.
This is fine, it was an experiment and I got it working.
Then, 6 hours later, the poll started the error message again and I had to convert it back to nomination and start the poll again. We have the poll set to be open for the next 10 days. I’m hoping this doesn’t happen again in that process.
Is the need to press the start poll button an expected behavior of the plugin?
Ah I misread one part of your analysis. There’s a user_private_message status message that goes out to everyone on the discourse (who can see the poll) that says the poll is open as well. You might want to reproduce the hour delay for the last status change as well for them.
Not sure if I’m an isolated case, but I’ve been experiencing errors on post updates with the latest Discourse upgrade. I fixed the issue by removing the Elections plugin. Just posting here in case its a more wide spread issue that needs a plugin update.
It LOOKS like you’ve recently updated to a version greater than 2.2.0 beta 3.
The entire structure of where polls are stored was changed in beta 4 (I think).
Instead of being JSON in custom fields, polls now have their own tables.
I’ve written an internal plugin that uses polls heavily and have recently had to refactor my code to achieve the same.
If I’m right then the elections plugin will need refactoring too.
