I’m wanting to change our Discourse email notifications to be sent via a service that only supports sending via an API rather than a standard SMTP relay. I’m not finding any current settings or plugins or obvious way of doing this. The closest I’ve seen is maybe using a webhook to send info to the api or an interstitial api. Questions:
- Is there already a way to send email via api instead of smtp that I’m just not finding?
- If not, is there a way to get any notifications that would normally trigger an email via web hook?
- If not, is there a way via a plugin to override normal email sends and do a custom thing instead?
Any answers/pointers on the above would be much appreciated!
