Emails stop sending (Temporary failure in name resolution)
After updating Discourse to 189b4c4992, Don experienced email delivery failures with Mailgun EU, encountering the error Temporary failure in name resolution. The issue appeared to stem from DNS resolution problems, as confirmed by Simon_Manning, who noted similar issues with Linode’s DNS failing to resolve mailgun.org domains. Though Don hosts on Vultr Frankfurt and confirmed Mailgun’s systems were operational, the DNS issue persisted. Simon_Manning suggested switching to Google DNS (8.8.8.8) as a workaround, which Don confirmed resolved the problem immediately. The root cause likely involved transient DNS propagation or caching issues affecting certain providers’ resolvers, while Google DNS remained unaffected. This fix restored email functionality without requiring changes to Mailgun or Discourse configuration.
Hello,
I updated in admin today to 189b4c4992 and and since then the emails stop sending. I use Mailgun EU.
I have got this error in /logs Job exception: getaddrinfo: Temporary failure in name resolution
And this in Sidekiq Jobs::HandledExceptionWrapper: Wrapped SocketError: getaddrinfo: Temporary failure in name resolution
Thank you for any help to fix this! :slightly_smiling_face:
Backtrace
/usr/local/lib/ruby/2.7.0/net/smtp.rb:539:in `initialize'
/usr/local/lib/ruby/2.7.0/net/smtp.rb:539:in `open'
/usr/local/lib/ruby/2.7.0/net/smtp.rb:539:in `tcp_socket'
/usr/local/lib/ruby/2.7.0/net/smtp.rb:549:in `block in do_start'
/usr/local/lib/ruby/2.7.0/timeout.rb:95:in `block in timeout'
/usr/local/lib/ruby/2.7.0/timeout.rb:105:in `timeout'
/usr/local/lib/ruby/2.7.0/net/smtp.rb:548:in `do_start'
/usr/local/lib/ruby/2.7.0/net/smtp.rb:518:in `start'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/lib/mail/network/delivery_methods/smtp.rb:109:in `start_smtp_session'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/lib/mail/network/delivery_methods/smtp.rb:100:in `deliver!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/lib/mail/message.rb:2141:in `do_delivery'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/lib/mail/message.rb:253:in `block in deliver'
actionmailer-6.1.4.1/lib/action_mailer/base.rb:559:in `block in deliver_mail'
activesupport-6.1.4.1/lib/active_support/notifications.rb:203:in `block in instrument'
activesupport-6.1.4.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport-6.1.4.1/lib/active_support/notifications.rb:203:in `instrument'
actionmailer-6.1.4.1/lib/action_mailer/base.rb:557:in `deliver_mail'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/lib/mail/message.rb:253:in `deliver'
actionmailer-6.1.4.1/lib/action_mailer/message_delivery.rb:119:in `block in deliver_now'
actionmailer-6.1.4.1/lib/action_mailer/rescuable.rb:17:in `handle_exceptions'
actionmailer-6.1.4.1/lib/action_mailer/message_delivery.rb:118:in `deliver_now'
/var/www/discourse/lib/email/sender.rb:267:in `send'
/var/www/discourse/app/jobs/regular/user_email.rb:83:in `send_user_email'
/var/www/discourse/app/jobs/regular/user_email.rb:38:in `execute'
/var/www/discourse/app/jobs/base.rb:232:in `block (2 levels) in perform'
rails_multisite-3.0.0/lib/rails_multisite/connection_management.rb:80:in `with_connection'
/var/www/discourse/app/jobs/base.rb:221:in `block in perform'
/var/www/discourse/app/jobs/base.rb:217:in `each'
/var/www/discourse/app/jobs/base.rb:217:in `perform'
sidekiq-6.2.2/lib/sidekiq/processor.rb:196:in `execute_job'
sidekiq-6.2.2/lib/sidekiq/processor.rb:164:in `block (2 levels) in process'
sidekiq-6.2.2/lib/sidekiq/middleware/chain.rb:138:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:138:in `call'
sidekiq-6.2.2/lib/sidekiq/middleware/chain.rb:140:in `block in invoke'
sidekiq-6.2.2/lib/sidekiq/middleware/chain.rb:143:in `invoke'
sidekiq-6.2.2/lib/sidekiq/processor.rb:163:in `block in process'
sidekiq-6.2.2/lib/sidekiq/processor.rb:136:in `block (6 levels) in dispatch'
sidekiq-6.2.2/lib/sidekiq/job_retry.rb:112:in `local'
sidekiq-6.2.2/lib/sidekiq/processor.rb:135:in `block (5 levels) in dispatch'
sidekiq-6.2.2/lib/sidekiq.rb:38:in `block in <module:Sidekiq>'
sidekiq-6.2.2/lib/sidekiq/processor.rb:131:in `block (4 levels) in dispatch'
sidekiq-6.2.2/lib/sidekiq/processor.rb:257:in `stats'
sidekiq-6.2.2/lib/sidekiq/processor.rb:126:in `block (3 levels) in dispatch'
sidekiq-6.2.2/lib/sidekiq/job_logger.rb:13:in `call'
sidekiq-6.2.2/lib/sidekiq/processor.rb:125:in `block (2 levels) in dispatch'
sidekiq-6.2.2/lib/sidekiq/job_retry.rb:79:in `global'
sidekiq-6.2.2/lib/sidekiq/processor.rb:124:in `block in dispatch'
sidekiq-6.2.2/lib/sidekiq/logger.rb:11:in `with'
sidekiq-6.2.2/lib/sidekiq/job_logger.rb:33:in `prepare'
sidekiq-6.2.2/lib/sidekiq/processor.rb:123:in `dispatch'
sidekiq-6.2.2/lib/sidekiq/processor.rb:162:in `process'
sidekiq-6.2.2/lib/sidekiq/processor.rb:78:in `process_one'
sidekiq-6.2.2/lib/sidekiq/processor.rb:68:in `run'
sidekiq-6.2.2/lib/sidekiq/util.rb:43:in `watchdog'
sidekiq-6.2.2/lib/sidekiq/util.rb:52:in `block in safe_thread'
Is your Discourse instance hosted with Linode? (Possibly Atlanta, specifically) I had this issue within the last hour or two with Linode’s default DNS server returning SERVFAIL when requesting any mailgun.org domain.
I’m unclear as to why that was the case but I switched to Google DNS temporarily and after a while, (20-30 minutes, I think) Linode’s DNS started resolving mailgun.org domains again.
Hi Simon,
Thanks for the quick reply. :slightly_smiling_face:
I hosting with Vultr Frankfurt. Never happened this before. Only when Mailgun crashed but I checked it and seems to All Systems Operational.
I wonder if there is a DNS problem with the provider Mailgun use. DNS caching can be kinda funky so one name server might get hit by a problem almost immediately while another never notices it, or at least doesn’t propagate it.
Google’s public DNS (8.8.8.8) appears to still be resolving it correctly so switching to that temporarily or adding it as a permanent fallback on your server should get your emails sending again.
Thank you Simon! :slightly_smiling_face: It works perfect! :heart:
