הטמעת נושאים הדורשים כניסה ו-DiscourseConnect
סיכום מבוסס בינה מלאכותית
Aubreyholland is trying to embed a list of topics from their Discourse forum (community.withgrayce.com) into their own site using d-topics-list. However, since their forum requires login via DiscourseConnect, the iframe redirect is causing a 419 error locally, indicating an expired login. Aubreyholland is unsure if this approach is viable and is seeking guidance on embedding topics when login is required. Falco suggests that the issue may be specific to local testing and that it should work fine in production.
I have my own site on which I would like to embed a list of topics. My forum is set up on community.withgrayce.com, and it requires login to see content using only DiscourseConnect as a login method. I’ve got the d-topics-list set up for this on my site. What’s happening is:
  • The iframe created by d-topics-list loads the URL https://community.withgrayce.com/embed/topics?discourse_embed_id=de-d4px4nnxj&per_page=5
  • Because login is required, that URL does a redirect to my discourse conect url. I’m testing locally, so this goes to http://localhost:3001/sso?sso=SSO_PARAMS_SNIPPED
  • That URL loads a page that hits an API to get the SSO redirect and then sets window.location.href with that URL within the iframe. I’ve tested that the SSO works correctly in general using this technique.
  • When the iframe tries to load the SSO redirect it gets back a 419 saying the the login has expired.
I can’t figure out why the 419 is happening in this case, but also is this approach doomed to fail? Is there a workable way to embed the list of topics when login is required and using discourse conect?
Thanks!
This will work fine in production, but testing it locally is tricky.
