Hi,
Does this code make sense to anyone else? Any ideas on why a 429 is being returned?
In various ways I am finding an ember_jquery-530b142 in the report that returns a 429 error.
Hi,
Discourse Ajax function uses jQuery under the hood, so every rate limit error coming from the Discourse will have jQuery somewhere in the backtrace.
Ok. Is there a good way to go a step back and find the origin of the rate limit error?
Does it happens when.using your instance normally? If it does, browsers developer tools will show you exactly why.
Hi, it does, but I am not sure where to look within the developer tools. Evidently the screenshots above are of the wrong error screen to find the source of the 429 error.
@Falco, Is there a particular browser you use for debugging? And is there a specific window or tool you recommend for identifying the source of 429 errors? Many thanks in advance!
Both Firefox and Chrome will show 429 sources in Network and Console tabs.
