In my Discourse web, when i touch in image on Android Device or laptop, the image not display with popup but go to the link image.
How can i view image same Meta page?
Thank you!
I can see those buttons on your site using safe mode to disable unofficial plugins. So the issue is probably a plugin
2 לייקים
When I choose either of these options then Move Button is display
- Disable unofficial client-side plugin customizations
- Disable all client-side plugin customizations
What is the next step I take?
לייק 1
I can see the lightbox being blocked on your site:
As Moin stated, the issue is from a plugin.
Looking at your plugins list, there is a suspicious one: Discourse Events Extra.
What is this plugin? I can’t find any information about it.
I see some possible code that could interfere with the lightbox.
2 לייקים
Thank you so much, i disable this plugin ![]()
לייק 1
