Enabling TLS 1.3
Is it possible to enable TLS 1.3 on Discourse? How is the local Nginx configured?
We disabled TLS 1.0 and 1.1 in mid 2018 per this topic.
Do we have TLS 1.3 support at least enabled somewhere @mpalmer?
2 לייקים
No, I don’t think we’ve turned on TLS 1.3 anywhere yet.
3 לייקים
We run NGINX 1.5 at the moment in the containers:
Per:
We only enable TLSv1.2
I am mixed on enabling TLSv1.3 until RFC 8446: The Transport Layer Security (TLS) Protocol Version 1.3 | RFC Editor is ratified though.
For the time being simply adding another template after the ssl template with:
- replace:
   hook: ssl
   filename: "/etc/nginx/conf.d/discourse.conf"
   to: |
     ssl_protocols TLSv1.2 TLSv1.3;
Would do the trick, the question though is if this is a trick you want to do given the protocol is still not ratified (even though it is being implemented)
5 לייקים
We just release a new base image with support for TLS 1.3 :tada:.
8 לייקים
When I look at the nginx config file inside the container, it has these settings:
SSL Settings
    ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
Should the references to TLSv1 and TLSv1.1 be dropped because of the BEAST attack?
Two different site checkers tell me TLSv1 and TLSv1.1 are not enabled, not sure where they’re disabled from.
That’s defined here
